Go Back   Grass Valley Forums > Converters > ADVC
Reply
Thread Tools Display Modes
Old 02-02-2009, 02:17 PM   #1
cmt100
Junior Member
Default ADVC 55+TBC or ADVC 300?
I need to clean up some old Hi8 tapes as my ADVC 55 doesn't like the synchronization on them. But I can't decide whether to stick with the ADVC 55 and get a time base corrector like the TV One Task 1T-TBC or switch over to the ADVC 300. So help needed to make a decision.
My thoughts and questions are:
Option 1 - ADVC 55 + TBC
One more cable connection so possibly more signal degradation?
The TBC only processes the s-video so what happens to the audio?
Option 2 - ADVC 300
Does the 2D 3D y/c work with PAL tapes? there's a note which says "NTSC only" but it's not clear which bit it is referring to
What's the difference between Line TBC and Full frame?
Does the 300 offer additional filters not found on a separate TBC?
I'd really like a guaranteed to work solution as well!
cmt100 is offline   Reply With Quote
Old 02-03-2009, 01:50 AM   #2
kbosward
Senior Member
Default
It's unusual that your ADVC-55 doesn't like your Hi8 tapes, which are normally good quality as far as sync goes. Are you sure you have the DIP settings correct (#1 on and #2 off for PAL)? Or it could be that your Hi8 camera needs an alignment adjustment. Digital converters are less forgiving than analog TVs of video which has marginal sync. I found with my old Video8 camera that my ADVC-300 was losing sync and I ended up pulling the camera apart and adjusting the alignment (it is a mechanical adjustment) and have had no problems since.
The ADVC-300 has only a Line Time Base Corrector, that is it does not do full frame sync correction, only line sync correction. So you are better off with a full TBC with either converter.
If your Hi8 player has S-video output, then the 3D Y/C (or lack of it on PAL) does not matter, since S-video already has Y and C separated. According to the web page, the ADVC-300 doesn't do 3D noise reduction in PAL, but I have found that enabling it in PAL does seem to make a difference (to my eye) on grainy videos (e.g. those filmed in low light), so now I'm not so sure.
There are many other filters and adjustments available on the ADVC-300. I posted a list of settings here: showpost.php?p=29923. You can also see some samples of filtering done by the ADVC-300 on this forum.
Ken.
kbosward is offline   Reply With Quote
Old 02-03-2009, 08:44 PM   #3
cmt100
Junior Member
Default
Thanks for the info and links.
DIP settings are definitely on PAL and most of my tapes have been fine. I'm a bit wary of tweaking with my camcorder in case I make it worse and not better.
The tapes causing problems are ones which I have done a lot of tape based editing on in the past, so stretching may be an issue. They also have low light and grainy digital zoom images which the ADVC 55 doesn't seem to like.
I'm going to investigate the separate TBC option again but as they only process the s video will it lose sync with audio?
Old 02-03-2009, 10:31 PM   #4
GrassValley_BH
Demystifier/Analogizer
Default
TBC will introduce delay. Some are smart and can also delay the audio as well so they stay in sync.
GrassValley_BH is offline   Reply With Quote
Old 02-05-2009, 08:16 AM   #5
cmt100
Junior Member
Default
I've read about the methods of TBC on Wikipedia but I'm still confused as to what I need. All my tapes play and display fine on the camcorder viewer or a TV, while on the ADVC 55 the green/red light flickers at the particular areas of tape it doesn't like, so I'm guessing that the sync is just slightly out.
How good is the ADVC 300 Line TBC at correcting for these marginal sync conditions?
Old 02-05-2009, 02:34 PM   #6
kbosward
Senior Member
Default
Quote:
Not particularly good, as I said earlier it has a Line TBC, not a full-frame TBC. I'm not even certain what a LTBC does, but I think it helps to remove jagged edges at the sides of the video picture.
I've seen some people report that they use a Datavideo TBC-1000, which apparently is relatively "inexpensive" as far as TBCs go.
Maybe you could hire one to see what difference it makes, to save spending lots of money?
Ken.
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
ADVC 300 Analogue & Digital In Lights both on!! MarrsieBoy007 ADVC 10 01-05-2010 01:54 PM
Video from PC through ADVC 300 to monitor ingvarai ADVC 8 06-10-2009 05:07 PM
Compression Settiing in ADVC 300 higherground ADVC 1 09-25-2007 04:52 AM
Compatibility of ADVC 300 with NLEs beevlad ADVC 2 06-20-2007 09:35 AM
ADVC FAQ (updated 2007/05/04) GrassValley_KH ADVC 0 05-04-2007 11:14 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
