Go Back   Grass Valley Forums > Converters > ProCoder
Reply
Thread Tools Display Modes
Old 10-20-2008, 02:50 AM   #1
shueardm
Senior Member
Default Unofficial iPhone 3G/iPod Touch (2nd Gen) presets for ProCoder 3
These presets are placed under "Handheld" menu in the ProCoder 3 prestes.
You need to extract the download to the following locations. Please enable "show hidden files and folders" in your Folder Options view.
Windows XP
C:\Documents and Settings\All Users\Application Data\Grass Valley\ProCoder 3\User Presets.
Windows Vista
C:\ProgramData\Grass Valley\ProCoder 3\User Presets.
Notes:
-Take no notice of the estimated time for job completion when converting.
-Play with the data rate as you will but generally you won't need to "up it" as it's set for high quality. You can change data rate under the "modify exporter settings" toggle.
-Don't change the frame rate, iPhone is 30fps
__________________
VIDEODESK AUSTRALIA http://videodesk.com.au
shueardm is offline   Reply With Quote
Old 10-24-2008, 12:53 AM   #2
GrassValley_KH
Mr Sparkle
Default
Tested OK with 2nd gen iPod Touch.
GrassValley_KH is offline   Reply With Quote
Old 10-25-2008, 08:44 AM   #3
rapcon
Member
rapcon's Avatar
Default
Quote:
What happens if the source video is 25 frames as they would be in PAL countries?
Regards Phil C.
rapcon is offline   Reply With Quote
Old 10-25-2008, 04:47 PM   #4
GrassValley_KH
Mr Sparkle
Default
ProCoder transcodes the frame rates accordingly. Though with that said, I could have sworn the Mac OS application I use (FFMPEGX) makes iPod Touch files with 25fps. I'll have to check into that.
But at least what Mark has provided above will work without a problem.
Old 03-14-2009, 04:11 AM   #5
darkman66
Junior Member
Default
Can you explain this statement to me please? It's telling me 5 hours left and moving extremely slow. I'm converting a 260 mb VOB file and using the 16x9 native resolution preset.
darkman66 is offline   Reply With Quote
Old 03-15-2009, 07:50 AM   #6
shueardm
Senior Member
Default
Hi
I am sorry I haven't done one for a while but i do remember that it showed it would take forever but it didn't. I can't remember how long it actually took but it wasn't anywhere near as long as it stated. All of a sudden (when it said hours to go) it just finished (completed)
__________________
Old 01-30-2011, 11:13 PM   #7
swsw1550
Senior Member
swsw1550's Avatar
Default
Also look at Badaboom for Iphone 3G ect ect ect, very fast program, http://www.badaboomit.com/
__________________
swsw1550 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
Unofficial MPEG-2 and H.264 Blu-ray presets for ProCoder 3 shueardm ProCoder 230 10-07-2013 04:06 AM
Unofficial Sony PSP presets for ProCoder 3 Mr Bill ProCoder 27 01-08-2011 04:01 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
