Go Back   Grass Valley Forums > Editors > EDIUS: Compatible Hardware and Accessories
Reply
Thread Tools Display Modes
Old 03-14-2019, 05:34 PM   #1
edver1
Senior Member
Default Influence of the motherboard
How big is the influence of the motherboard cc. the speed / reliability of the system.
Thinking of a new system with a i9 9900K cpu,so the chipset is already determent ,but I don't need all the bells and whistles,and colour scheme's i certainly don't need !
I use at the moment an Asus x99 and that brand I like because it's stable and easily to configure.
Some suggestions ?
Edd
edver1 is offline   Reply With Quote
Old 03-15-2019, 02:41 AM   #2
dpalomaki
Senior Member
Default
The performance differences among MBs given the same chip set, processor, RAM, configuration, and speed are minimal. Consider reliability reports, after sale support, the features you need, and if important the cost.
There are lots of MB reviews, mostly oriented to gaming performance and over clocking; however, they often give a bit of info on video editing-related tests too. So search for and check them out, as well as comments you see on this and other boards. And heck the MB's makers web support forums to get a feel for problems, if any, among the user community.
FWIW I've been using ASROCK Intel CPU boards recently and have been satisfied.
dpalomaki is offline   Reply With Quote
Old 03-15-2019, 11:56 AM   #3
David Clarke
Senior Member
David Clarke's Avatar
Default
I generally use Gigabyte and go for the "cheaper" end models with no bells and whistles. Sometimes more expensive models add things which are meant to help - like the ability to share resources on PCI slots in a fancy way - which actually cause problems.
For my i9 9900K system I actually have an MSI z390 Pro motherboard which I bought because of a special offer on Black Friday. It works very well.
It also happened to have two internal USB3 headers - great for my system as I had the USB3 on the case to plug in and a card reader to plug in. It also had a VGA out on the motherboard as well as an HDMI which I find useful. It only has two big PCIe sockets though which is enough for my nVidia card and a BM Intensity pro 4K, but if I want to add another big card I can't which I could on some other boards. These are the main things I would look at - USB3 headers, PCIe slots and GPU outputs. You may also want to check how many and what type of USB3 ports are on the back.
Before I bought this I had set up systems with a Gigabyte board and the performance was the same, but it had different variations of the above.
__________________
David Clarke is offline   Reply With Quote
Old 03-15-2019, 04:01 PM   #4
dpalomaki
Senior Member
Default
Another potential issue is the number (and level) of SATA connectors. Some boards are limited in this regard. Some may offer stuff you may or may not want or need; e.g., like Bluetooth, WiFi.
Old 03-15-2019, 06:45 PM   #5
edver1
Senior Member
Default
You both mention the things I'm looking at : Sata ports (at least 6 and 6GB/s );USB 3 & 3.1;M2.0 (2 or more ).
The GPU is on the Intel boards always the same,so no difference there.
I read an artikel,that Intel is planning to stop producing there CPU's with internal GPU,so that would mean no more Quick Sync ?
I'm thinking on a Asus TUF Z390-pro gaming board,it tics all the boxes and it should be reliable and fast.
That in combination with the I9-9900K would me get on speed for 4K editing.
Always open for suggestions,I know there are already many posts about this item,but technology go's fast and nobody knows it all !
THX
Edd
Old 03-16-2019, 01:39 PM   #6
David Clarke
Senior Member
Default
The Intel GPU is in the processor not on the motherboard. I have not used that motherboard but no reason to think it won't work.
__________________
Old 03-16-2019, 02:40 PM   #7
edver1
Senior Member
Default
The board I'm using at the moment is very stable and I never had any problem whit it.
The brand Asus has a good reputation here,and I read a lot reviews before I made a decision,that is what I'm doing now also.
The problem is how more You read the more indecisive You ( I ) get.
Editing is for me a 100% hobby whit zero income of it.
So I read al lot on forums to get real experience for users.
Using Edius is this the best place to look for it, and I learned a lot here !
Going a step forward,do I need to reinstall Win 10 & Edius with an new board ?
THX for all the responses !
Edd
Old 03-16-2019, 03:08 PM   #8
dpalomaki
Senior Member
Default
Quote:
Originally Posted by edver1 View Post
...Going a step forward,do I need to reinstall Win 10 & Edius with an new board ?
Edd
A new MB will likely require new drivers for the board devices. And you will likely need to revalidate the windows license due to processor and board changes exceeding the Windows license threshold.
While you could probably just move the drives to the new MB and update the drivers, a clean build will be much better. Be sure to do the Edius uninstall properly to avoid license issues.
Old 03-17-2019, 04:57 AM   #9
Senior Member
Jerry's Avatar
Default
I just want to mention that you are talking about two different types of boards here.
You are currently using an X99. This board utilizes a chip that affords 40 PCI-E lanes from the CPU.
The board you are looking at the Z390 chipset, gives you 16 PCI-E lanes from the CPU. So, if you decide that you want to work in 3840x2160 50p, you will need an 8x I/O card to view this
on an external monitor. The Z390 chipset would accept the 8x card, but your graphics card would be reduced to 8x. You may or may not notice the difference.
If you are only using a 16X lane GPU and a 4X lane I/O card, the Z390 chipset should be able to handle that with the right motherboard. Each manufacturer modifies the Intel chipset to suit their boards. Usually, the more expensive boards have more items available; however, all of the options will not be able to be used at the same time.
Here's an example. My Asrock board(Z97) came with 10 Sata ports. Asus boards at that time were normally maxing out at 8 Sata Ports. Normally, only providing 6.
If you want the Z390 and you need more lanes, look into the Asus WS 390 Pro or Supermicro Workstation boards. These will be more expensive due to what they do.
More than likely, you will be able to find an Asus board to fit your needs.
You need to decide the components, and lane counts, that will be added to the board prior to selecting the board. If you intend on using M.2 drives, PCI-E lanes need to be calculated into that decision as well.
Do the math before buying a board.
__________________
Main System: Azrock Z97 Extreme 6, 4790K@4.7Ghz, 32gb ram, Corsair H110, Win10 Pro 64, Samsung 850 pro, E7.5/8.5/E9 on separate SSD drives, HD Spark, Intensity Shuttle, 12tb RAID 0 on backplane ,2 BD, Benq 27 and Hanns-G 28 monitors, CC 2019, GTX 1080ti SC Black.
Both systems on Gigabit network
Second System: EditHD Ultimax-i7, X58, 980x@3.74, Corsair H80, Win764, 24gb ram, Storm 3g, Samsung 840 Pro 256, 4tb and 6tb RAID 0 on backplane, GTX 980ti Classified, Edius 9, Apple 30", Samsung 24", dual BD.
Jerry is offline   Reply With Quote
Old 03-17-2019, 03:19 PM   #10
edver1
Senior Member
Default
You just gave me serious good advice !
My GPU card is a Asus GTX660,already an old "beast" my CPU is a I7 5820 so not all the lanes provided by the motherboard!
Perhaps I would be better of with a faster/more lanes I7,but they are very hard to find here and there price is even hard to swallow + no quicksync !
That's the mean reason to change the whole thing.
I "stick" to Asus because there really nice UEFI bios and there stability.
If You have better combinations => I'd love to hear them !
Much appreciate Your'e input .
Edd
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
Motherboard VideoMagicPro EDIUS: Compatible Hardware and Accessories 3 10-09-2018 02:36 PM
Motherboard tdh10 EDIUS: Compatible Hardware and Accessories 0 09-24-2018 10:02 AM
best motherboard ? wael EDIUS: Compatible Hardware and Accessories 2 02-05-2009 05:12 PM
Would this motherboard be ok? Vman Editing with EDIUS 4 03-05-2008 06:09 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
