Go Back   Grass Valley Forums > Converters > ADVC
Reply
Thread Tools Display Modes
Old 10-19-2018, 08:25 PM   #1
astrogeorge
Junior Member
Default ADVC 3000 firewire ports no longer working
The firewire ports on my ADVC-3000 has stopped working, before this happened the firewire cable was pulled out from the back of the computer. After reconnecting the cable the encoder went dead with no display however the back light was on. After a while and turning the unit off and on the unit came back on however no firewire connection with computer. I tried a camcorder which connects with the same cable so know its an issue with the ADVC-3000
astrogeorge is offline   Reply With Quote
Old 10-20-2018, 04:17 PM   #2
BernH
Senior Member
BernH's Avatar
Default
Quote:
It isn't uncommon when firewire cables get "hot swapped" for there to be a little bit of ESD that can damage the firewire chips. When firewire was a lot more common than it is now, there were companies like Kramer that made in line ESD protectors to try to avoid this problem.
That said, if the port on the computer still works and the same cable works, it is likely that you had an ESD discharge that damaged the ADVC. Unfortunately there is no user fix for this. It requires having the chip replaced by a service technician. GV support may be able to repair this for you.
__________________
Edius WG 9.51.5619, various 3rd party plugins, VisTitle 2.8.0.5, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 4TB Internal RAID 0/stripe (2x2TB Seagate SATAIII HDD's, Win7 Software RAID 0/stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
BernH is offline   Reply With Quote
Old 10-20-2018, 05:08 PM   #3
astrogeorge
Junior Member
Default
Thanks for ypur reply, contacted GV support who tell me they no longer support the ADVC 3000 as it's reached end of life. Was looking to see if anyone knew anybody else that could do repairs
Old 10-21-2018, 04:23 PM   #4
BernH
Senior Member
BernH's Avatar
Default
I spent 14 years as an electronics bench technician and have replaced several of these kind of firewire IC's and fuses (often called link IC's) in Sony camcorders.
You would need to find a good electronics technician that can hopefully get creative in finding the replacement parts, as they may be out of production now or in limited supply, but I can tell you from experience, without any service information, schematic diagrams, parts lists, or at the very least a detailed IC specification sheet, it is difficult for the electronics technician to do a thorough job and ensure that he/she checks all the related components for damage or failure and gets the exact replacement part and/or applies any service bulletins to prevent future problems.
While link IC's are easy to test, without that service information, it may be difficult to determine if the firewire IC is working or not, as there may be no way of knowing what voltage or signal should be seen on any given leg of the IC when it is working correctly, and tracing circuits without the schematic can sometimes be difficult, depending on how good the circuit board layout is.
Finding said Electronics Technician, however, may be difficult as the days of repairing most electronics disappeared about 10 to 15 years ago as manufacturers started moving to a factory service only or a repair by replacement model, which is part of the reason that I am no longer working in that field. I don't even have a lot of the test equipment any more.
Hopefully you can find someone in your area that can help you out.
__________________
Old 10-21-2018, 05:23 PM   #5
astrogeorge
Junior Member
Default
Thanks, I have a guy I use for repairing and maintaning all my old video eqiptment. I also have an old ADVC-1000 which I don't use now, I'm hoping I can use the firewire parts from that to repair the ADVC-3000.
George
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
HDSpark no longer working vactive Editing with EDIUS 5 06-29-2015 11:31 AM
Advc 3000 manual pittersaust ADVC 1 08-13-2013 10:42 PM
Are both ADVC 700 Firewire ports hot? TWiTColleen ADVC 1 03-30-2009 11:25 PM
ADVC 3000 works with Mac??? shazi639 ADVC 1 09-13-2007 10:58 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
