Go Back   Grass Valley Forums > Editors > MYNC
Reply
Thread Tools Display Modes
Old 03-20-2018, 08:09 PM   #1
christian_hh
Junior Member
Default Audio issue when importing a MYNC storyboard
Importing an FCP storyboard from MYNC into EDIUS 8.53 results in two mono audio tracks. For simple cutting I would rather have one stereo track.
Whatever I try with audio mapping in the project preferences - there is no change.
Is there any way to either 1) import audio directly into one stereo track or 2) merge the mono tracks to a stereo track?
christian_hh is offline   Reply With Quote
Old 03-20-2018, 11:30 PM   #2
antonsvideo
Senior Member
antonsvideo's Avatar
Default
add the mono/stereo switch to the mode bar, then switch to stereo prior to dragging clips to timeline
https://www.videoproductions.com.au/...ode-switch.mp4
__________________
EDIUS 9 WG with Matrox MXO2, Gigabyte X299 UD4 Pro, Intel Core i9 9960X 16 Core, 32 Threads @ 4.3Ghz, Corsair Water Cooling, Gigabyte RTX-2070 Super 3X 8GB Video Card, Samsung 860 Pro 512GB SSD for System, 8TB Samsung Raid0 SSD for Video, 2 Pioneer BDR-209 Blu-ray/DVD burners, Hotswap Bay for 3.5" Sata and 2.5" SSD, Phanteks Enthoo Pro XL Tower, Corsair 32GB DDR4 Ram, Win10 Pro
antonsvideo is offline   Reply With Quote
Old 03-21-2018, 10:24 AM   #3
christian_hh
Junior Member
Default
Hi Anton,
thanks for your reply. This works well when I import clips to an existing sequence. However, when importing a storyboard from MYNC a new sequence is created by the system and there are always two mono tracks, regardless the project- or sequence-settings
Old 03-21-2018, 10:28 AM   #4
antonsvideo
Senior Member
Default
that seems to be a shortcoming of Mync then? I never use it so I have no further ideas
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
Exporting a Mync Storyboard to EDIUS spurfilm MYNC 2 02-23-2018 11:24 AM
Using Storyboard in Mync on a laptop on a 2nd PC Alpha Video MYNC 4 09-07-2017 10:04 AM
How to retrieve a Mync storyboard ? fasquin MYNC 5 07-18-2017 11:19 AM
importing audio issue... sherri@tidychaos.c Editing with EDIUS 4 10-14-2008 07:22 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
