Go Back   Grass Valley Forums > Editors > MYNC
Reply
Thread Tools Display Modes
Old 02-23-2018, 10:15 AM   #1
spurfilm
Senior Member
Default Exporting a Mync Storyboard to EDIUS
I am creating storyboards in Mync, to be used in EDIUS.
At the moment it seems the only way to get the individual clips and their original timecode from the Storyboard in Mync is to export a FCP XML and then import that XML into EDIUS. Which works fine.
If I try to use Mync as a tool from within EDIUS and import a storyboard it arrives as a single timeline (containing all my selected clips), and the original timecodes are lost.
Is there some way to get the individual clips and original timecode to arrive by clicking somewhere within EDIUS, or is the only way to go via export/import of a FCP XML?
__________________
Rick
SPURFILM
EDIUS WG 9.51.5532 Tower > Win10 Pro 64-bit on 512GB Samsung 850 Pro SSD, Nanoxia Deep Silence Case, Asus X99-S Mobo, Intel i7-5820K Haswell-E @ 3.30GHz O/C to 4GHz, 32GB Crucial DDR4 @ 2133MHz, NVIDIA GeForce 980 Ti 6GB + dual 1920x1080 monitors, BM Intensity Pro 4K + 3840x2160 monitor, LG Blu-Ray writer, Storage: 16TB WD RED RAID0. EDIUS WG 9.51.5532 Field Laptop > Acer P645-M, 14" 1920x1080, 256GB SSD, Win10 Pro 64-bit, Intel dual-core i7-4500U Haswell @ 1.8GHz, 8GB DDR3.
spurfilm is offline   Reply With Quote
Old 02-23-2018, 10:46 AM   #2
GrassValley_SL
Moderator
GrassValley_SL's Avatar
Default
Time code is always there. Double click the sequence and you have access to all the clips. ..with time code.
Or if you always want individual clips on the timeline right click on the sequence in the bin and choose open sequence.
This is the same for sequences you make in EDIUS. You can use them as a clip or a timeline.
__________________
GrassValley_SL is offline   Reply With Quote
Old 02-23-2018, 11:24 AM   #3
spurfilm
Senior Member
Default
You are so right! It's my first time using Mync and I am finding it really useful on location, to send storyboards of selected material to the editor back at base. Really brilliant. Many thanks.
__________________
Rick
SPURFILM
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
Using Storyboard in Mync on a laptop on a 2nd PC Alpha Video MYNC 4 09-07-2017 10:04 AM
How to retrieve a Mync storyboard ? fasquin MYNC 5 07-18-2017 11:19 AM
Edius -> Mnyc Catalog or Storyboard Romigo Editing with EDIUS 0 06-22-2017 12:24 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
