Go Back   Grass Valley Forums > Converters > FIRECODER Blu & Pegasus
Reply
Thread Tools Display Modes
Old 08-15-2017, 01:37 AM   #1
greymouse1
Junior Member
Default Just some firecoder Blu Questions Win7 32bit
Hi
i've just installed the card on my windows 7 32bit machine, and the firecoderwriter 1.11
the software is crashing when I choose transcode a .TS with an APPCRASH
and when run the program in Windows XP Service Pack 3 compatibility mode, it crashes saying "Quicktime initialized failed" even though it is installed etc
are there any fixes to these issues?
greymouse1 is offline   Reply With Quote
Old 08-16-2017, 04:50 AM   #2
greymouse1
Junior Member
Default
also can someone tell me if I want to use the firecoder blu card I need a spursengine plugin for the video editing suite i would like to use? have I got that right? thanks in advanced
Old 11-22-2017, 01:38 AM   #3
Andreas_Gumm
Senior Member
Andreas_Gumm's Avatar
Default
GV has discontinued the support in Edius version 6 or 6.5.
The very early end of life after a very short product cycle and the buggy piece of stand-alone software was a kick in the neck of the clients who have bought the card.
I have in mind that the last recent Firecoder version didn't support QuicktTime files reliable. Previous versions had different problems.
Maybe the TMPGEnc Spurs Engine plugin helps you better. It works with TMPGEnc Video Mastering Works 5, TMPGEnc 4.0 XPress and TMPGEnc Authoring Works 5.
http://tmpgenc.pegasys-inc.com/en/en...4xp_spurs.html
Andreas
Andreas_Gumm is offline   Reply With Quote
Old 11-23-2017, 10:41 PM   #4
Thor
Senior Member
Thor's Avatar
Default
Quote:
I don't know about Spurs engine or quicksync. All I can tell you is that after I installed a FCB card in my WinXP-32 computer, Edius 6 took 1/4 of the time needed to encode a blu-ray disc for me.
__________________
Regards,
Jon
Thor is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
Firecoder Blu MPPais FIRECODER Blu & Pegasus 1 07-30-2016 10:45 PM
Questions regarding Edius NX + 5D Mark II + Win7 64-bit alxwulf EDIUS: Compatible Hardware and Accessories 35 03-08-2010 11:47 AM
edius 5 and firecoder blu newbie questions speco FIRECODER Blu & Pegasus 2 07-03-2009 06:47 PM
is FireCoder Blu accerlate encoding only with FireCoder Writer? stanleychow FIRECODER Blu & Pegasus 5 03-30-2009 10:21 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
