Go Back   Grass Valley Forums > Converters > ProCoder
Reply
Thread Tools Display Modes
Old 07-18-2017, 08:02 PM   #1
craftech
Junior Member
Default Procoder 3.06 will not render 2-pass VBR
Been using Procoder 3.06 for several years for Mpeg 2 CBR encoding with sources created by Sony Vegas. Never had a problem. This time I have a 1 hr 43 min. job which forces me to a bitrate of 5302 so I figured I would try 2-pass VBR encoding for a little better quality.
I have been at it for several days and it crashes when it starts the second pass no matter how I render the source. The error message in Windows XP Pro SP3 is a Procoder application crash involving msvcr90.dll.
Anyone know about this problem?
Thanks,
John
Craftech Productions
craftech is offline   Reply With Quote
Old 07-21-2017, 06:01 PM   #2
craftech
Junior Member
Default How about if I roll back to the previous version?
It seems that no one has any ideas about this problem.
Grass Valley discontinued the product so that's out (and I never had a problem until now).
So what is the downside if I roll back to the previous version, and does anyone know how I would go about that if I wanted to try it?
Thanks,
John
Old 07-22-2017, 12:05 AM   #3
antonsvideo
Senior Member
antonsvideo's Avatar
Default
since you are using Windows XP, you could be running out of memory because Win XP can only give max 2GB to Procoder (try the encode again with Taskmanager open, and keep an eye on memory consumption)
or it could be that your Temp folder is full or that you are exporting to a drive that is Fat32 formatted
make sure you export to an NTFS drive with plenty space because of the Temp file created during Dual Pass
also, try and re-register the dll
1.Open Command Prompt
2.Then type regsvr32 msvcr90.dll and press enter. You should see a message saying registering dll was successful.Then click OK.
__________________
EDIUS 9 WG with Matrox MXO2, Gigabyte X299 UD4 Pro, Intel Core i9 9960X 16 Core, 32 Threads @ 4.3Ghz, Corsair Water Cooling, Gigabyte RTX-2070 Super 3X 8GB Video Card, Samsung 860 Pro 512GB SSD for System, 8TB Samsung Raid0 SSD for Video, 2 Pioneer BDR-209 Blu-ray/DVD burners, Hotswap Bay for 3.5" Sata and 2.5" SSD, Phanteks Enthoo Pro XL Tower, Corsair 32GB DDR4 Ram, Win10 Pro
antonsvideo is offline   Reply With Quote
Old 07-22-2017, 02:13 PM   #4
craftech
Junior Member
Default
Thanks for the help. I'll try that and post back next week (away for weekend). Love Procoder to render Vegas via frameserver and AviSynth. CBR looks great and always has. Just got to get the VBR working.
Regards,
John
Old 07-25-2017, 07:11 PM   #5
craftech
Junior Member
Default
regsvr32 msvcr90.dll "The specified module could not be found.
Tried installing Microsoft Visual C++ 2008 Redistributable Package (x86) TWICE and msvcr90.dll still could not be found.
A file search reveals the file (different versions) in several locations with various software, but not in the System32 folder. Don't want to take a chance on moving one over because there are different versions.
Any ideas?
John
Old 07-26-2017, 03:43 AM   #6
antonsvideo
Senior Member
Default
can you make a screenshot of the entire error message when it happens again
my Win XP memory is not as good as it used to be
__________________
Old 08-05-2017, 05:18 PM   #7
craftech
Junior Member
Default Error Messages
Here are the errors which ALWAYS happen no matter what you feed it using VBR 2-pass at start of second pass.
Old 08-06-2017, 02:19 PM   #8
craftech
Junior Member
Default
Submitted it a few days ago. Not sure why it hasn't been posted by moderators. I really appreciate your help.
John
Old 08-07-2017, 12:48 AM   #9
antonsvideo
Senior Member
Default
all I can suggest is to uninstall Procoder and delete all left behind folders and hidden folders
empty the Temp folder
install Procoder and test again
make sure no antivirus program is running while installing
if it fails, use the tool that will do the job every time with the same quality
http://tmpgenc.pegasys-inc.com/en/product/tvmw6.html
__________________
Old 09-14-2017, 07:24 PM   #10
Aivar00
Junior Member
Default
all i cant suggest is try to output diffrent drive and create new folder.
good luck,
Aivar
Aivar00 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
what speed of encoding should be for m2ts file to AVI by using Procoder 3.06? freda_yeo ProCoder 0 12-01-2011 02:26 AM
Procoder 3 3.06 MPEG-2 Exporter shorspace ProCoder 1 06-08-2011 12:27 AM
Procoder 3 update 3.06 available Albatros ProCoder 30 03-22-2011 08:38 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
