Go Back   Grass Valley Forums > Integrated Production & Playout > GV Edge
Reply
Thread Tools Display Modes
Old 06-21-2017, 09:12 AM   #1
Mahdi Hasan Nur
Junior Member
Default TXMAM _ POC failed to connect ip X.X.X.X
Suddenly i'm getting database error please help me asap. when i try to start POC it said "Failed to connect to database with ip "x.x.x.x" and i check main server TXmam it showed bellow massage and i tried also from browser gave me database error.
From command mode :
This database server IS ACTIVE
Statement failed, SQLSTATE = 54000
Implementation limit exceeded
-Transactions count exceeded. Perform backup and restore to make database operab le again
Statement failed, SQLSTATE = 08003
invalid transaction handle (expecting explicit transaction start)
dataserver - v3.95
firebird LI-V2.5.1.26351
assetinboximporter - v2.6
ingest_distri - v3.10
assetjobhandler - v1.11
pt_guard - v1.4
settingd - setd suite v1.20.1
txsettings - v1.10
Filesystem Size Used Avail Use% Mounted on
/dev/sda4 9.2G 5.5G 3.2G 64% /
udev 7.9G 136K 7.9G 1% /dev
/dev/sda2 8.2G 899M 7.3G 11% /var/log
/dev/sda3 383G 79G 304G 21% /publitronic
//X.X.X.X/SGLCache 75T 66T 8.7T 89% /publitronic/flashnet-cache
From Browser Mode
Database error
Error occured. You can retry your action by clicking a button below
Exception information:
Message: Firebird prepare error: Implementation limit exceeded Transactions count exceeded. Perform backup and restore to make database operable again
Stack trace:
#0 /usr/local/apache2/library/Zend/Db/Statement.php(115): Zend_Db_Statement_Firebird->_prepare('select? ...')
#1 /usr/local/apache2/library/Zend/Db/Adapter/Firebird.php(349): Zend_Db_Statement->__construct(Object(Zend_Db_Adapter_Firebird), 'select? ...')
#2 /usr/local/apache2/library/Zend/Db/Adapter/Abstract.php(467): Zend_Db_Adapter_Firebird->prepare('select? ...')
#3 /usr/local/apache2/library/Zend/Db/Adapter/Firebird.php(198): Zend_Db_Adapter_Abstract->query('select? ...')
#4 /usr/local/apache2/library/Zend/Db/Table/Abstract.php(823): Zend_Db_Adapter_Firebird->describeTable('USERS', NULL)
#5 /usr/local/apache2/library/Zend/Db/Table/Abstract.php(845): Zend_Db_Table_Abstract->_setupMetadata()
#6 /usr/local/apache2/library/Zend/Db/Table/Abstract.php(885): Zend_Db_Table_Abstract->_getCols()
#7 /usr/local/apache2/library/Zend/Db/Table/Abstract.php(969): Zend_Db_Table_Abstract->_setupPrimaryKey()
#8 /usr/local/apache2/application/models/Users.php(37): Zend_Db_Table_Abstract->info('name')
#9 /usr/local/apache2/application/controllers/LoginController.php(46): Application_Model_Users->userAuth('sysdb', 'masterkey')
#10 /usr/local/apache2/library/Zend/Controller/Action.php(513): LoginController->indexAction()
#11 /usr/local/apache2/library/Zend/Controller/Dispatcher/Standard.php(289): Zend_Controller_Action->dispatch('indexAction')
#12 /usr/local/apache2/library/Zend/Controller/Front.php(954): Zend_Controller_Dispatcher_Standard->dispatch(Object(Zend_Controller_Request_Http), Object(Zend_Controller_Response_Http))
#13 /usr/local/apache2/library/Zend/Application/Bootstrap/Bootstrap.php(97): Zend_Controller_Front->dispatch()
#14 /usr/local/apache2/library/Zend/Application.php(366): Zend_Application_Bootstrap_Bootstrap->run()
#15 /usr/local/apache2/htdocs/index.php(27): Zend_Application->run()
#16 {main}
Request Parameters:
array (
'controller' => 'index',
'action' => 'index',
'module' => 'default',
'username' => 'sysdb',
'password' => 'masterkey',
'Login' => 'Login',
Please help me if anyone know gow to solve it . Thanks in advance
Mahdi Hasan Nur is offline   Reply With Quote
Old 06-22-2017, 03:23 PM   #2
GrassValley_SL
Moderator
GrassValley_SL's Avatar
Default
Hi there,
Can you please contact our technical support?
They will be better equipped to help you in this case.
__________________
GrassValley_SL is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
DirectShow (IP camera) recording with sound from other source nath Editing with EDIUS 0 10-05-2015 10:09 PM
How to Connect olav246 Editing with EDIUS 1 09-28-2015 10:14 PM
Using Metadata from TXMAM alex177 GV Edge 1 08-07-2014 05:07 PM
Can't connect with DVR kt1709 Editing with EDIUS 1 08-02-2009 04:26 AM
K2 Connect Andy Editing with EDIUS 2 09-28-2007 06:23 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
