Go Back   Grass Valley Forums > Editors > Editing with EDIUS
Reply
Thread Tools Display Modes
Old 01-23-2017, 10:07 PM   #1
Bassman
Senior Member
Default Multicam Stutter at Cuts
I have been seeing this behavior for a while but it really bugs me when I am in the middle of a project. I have a 3 camera shoot in 1080p60 using the Panasonic AVC-Ultra Long GOP codec. This codec is not the easiest on systems but my system is not that old.
I am editing in 1/2 resolution with filters off in multicam. The buffer is reading 9/10 but when I get to a cut that was made the video will stutter just a little bit and keep going. The problem is this often knocks the audio/video sync out so it is tough to trust future cuts if you just let it play. So I am starting and stopping, replaying areas over and over.
I have always had issues with this codec. Things have improved a lot but this little multicam behavior makes it very difficult to edit. It would seem to me if I have a solid buffer reading things should play well even through the cuts.
After trying all kinds of setting changes and nothing making any difference I don't know what else to do to fix this. Do I really need a bleeding edge system just for a 3 camera 1080p60 edit?
__________________
Bassman is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
Audio stutter in Multicam (Edius 7.52) DiSoFilm Editing with EDIUS 11 03-20-2016 09:59 PM
Multicam stutter in 6,06 Philip Howells Editing with EDIUS 8 01-30-2012 01:36 PM
Making cuts using Multicam DMS Video Editing with EDIUS 9 01-20-2009 01:37 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
