Go Back   Grass Valley Forums > Integrated Production & Playout > GV Edge
Reply
Thread Tools Display Modes
Old 03-30-2016, 05:59 PM   #1
alatriste1
Junior Member
alatriste1's Avatar
Default OSX - El Capitan
I'm about to upgrade OSX, Is composer running ok under "El Capitan"
I'm using a mac book pro 2.3 Ghz Core i7.
__________________
FOX INTERNATIONAL
alatriste1 is offline   Reply With Quote
Old 04-25-2016, 09:52 PM   #2
alatriste1
Junior Member
alatriste1's Avatar
Default
Two months later no Grass Valley response... :/
__________________
FOX INTERNATIONAL
Old 04-25-2016, 09:58 PM   #3
GrassValley_PS
Moderator
GrassValley_PS's Avatar
Default
This is not an official forum and very few people visit here that would involve this product. You should contact tech support and open a ticket.
__________________
Main System: i7 6950X OC to 4.5GHz, ASUS RAMPAGE V EDITION 10, Corsair Dominator Platinum 64GB DDR4 2800, SAMSUNG 950 PRO M.2 512GB , GeForce GTX 1080ti SC Black, Corsair AX1200i PS, Phanteks Luxe Case, 16TB RAID (4)HGST Deskstar NAS 4TB, Corsair H115i CPU Cooler, AJA Kona 4, BMD Intensity Pro 4K, Win 10
GrassValley_PS is offline   Reply With Quote
Old 05-06-2016, 11:53 AM   #4
harveylexton
Senior Member
Default Edius 8 OS X
I wonder if GV will ever make Edius 8 work in EL Capitan. The reason is I use Mac and use VMware for win 10 but I find it crashing to much.
harveylexton is offline   Reply With Quote
Old 05-06-2016, 12:17 PM   #5
SoundFreak_HD
Senior Member
SoundFreak_HD's Avatar
Cool
The days of the mighty Mac are over and gone .....
While there was a good reason 20 years ago or so to go Mac anything audio and video related, due to the crapiness of Windows, things changed with Windows 7 and Windows 10 is great with any pro audio or video software and hardware.
If you really have the need to run Edius as an NLE you should consider adding a windows computer to your tool box.
If you build or buy a system comparable to a mac pro you'll find that there is virtually no difference between running a Mac or PC, it's just the chosen soft and hardware that defines the usefulness of the tools.
There are some Mac users here and maybe if you Google your way around this forum you can find them by reading some old threads / posts, once found shoot them a P.M. and I'm sure someone might reveal the hidden magic.
Not sure if indeed Edius 8 can runs smoothly on the system you want to run it on but I know of Edius 7 being used under Windows 7 on a Mac with stable results.....
__________________
Tony D.
EDIUS WG 9.51 / MATROX MXO2 LE / WIN10 Pro WS / LENOVO P71 Workstation laptop / XEON E3-1535M v6 / nVidia QUADRO P3000 6GB / Toshiba M.2 NVMe 512GB / Samsung 860 EVO 4TB / 32GB ECC RAM.
EDIUS WG 8.53
/ HDRX-E1 + HDBX-1000 H / WIN10 Pro / DUAL XEON X5470 / SUPERMICRO X7DWA-N / SUPERMICRO SUPERCHASIS SC745TQ-920B / INTEL 520 SSD 240GB / WD CAVIAR BLACK 4TB (many) / 32GB ECC RAM / GTX 770 4GB / 2x MOTU 896HD.
wavearts / neatvideo / tmpgenc / hitfilm / imaginate
SoundFreak_HD is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
ADVC 300 Picture Controller Download for Mac OS X (El Capitan) chumradio ADVC 2 01-20-2016 06:22 AM
Problema con el idioma español en el plugin Boris Graffiti de Edius 6 buzonpopulartv EDIUS: Compatible Third Party Products 2 12-17-2013 07:50 PM
Edius On OSX 10.5 nazmul_i Editing with EDIUS 3 05-19-2008 01:53 AM
ADVC110+OSX: does it work? francogatta ADVC 3 11-01-2007 05:49 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
