Go Back   Grass Valley Forums > Integrated Production & Playout > GV Edge
Reply
Thread Tools Display Modes
Old 03-05-2016, 05:25 AM   #1
ductuan
Junior Member
Default Please help me about k2 edge playout
please help me ! I used command line "./nexusproc restart all"
,but not effective . Thank you very much
And method created RecPack Channel on Channel Composer (My setting I/O SDI : 1,3,5,7 Input, 2,4,6,8 output) :(
ductuan is offline   Reply With Quote
Old 03-05-2016, 06:46 PM   #2
ductuan
Junior Member
Default
And pls tutorials method created RecPack Channel pack on Channel Composer !
Old 03-06-2016, 06:24 AM   #3
ductuan
Junior Member
Default
I am a customer has purchased K2 Edge Layout.
During the test run, the following error may often occur:
- When click Next (1 to 2 to 3 to 4 event LIVEinput) to select the input or when recorder Channel K2 Main and K2 Backup automatically shutdown, and can not be restarted by clicking the power button 1 times, should hold for a few seconds then turn it back.
- Currently, in the webpage interface manager (IP / txdashboard), the green lights of K2 Backup has grayed, despite all services are working
Grassvalley company please give me some advice to deal with the above issues or send engineers to intervene.
I think there is something wrong when changing INPUT port at Playout Control or IN/OUT port on the back of the K2 Edge Playout.
If there are warnings about the IN/OUT, please provide.
Old 03-06-2016, 06:34 AM   #4
GrassValley_PS
Moderator
GrassValley_PS's Avatar
Default
This forum is not official support. You should contact GV support directly.
__________________
Main System: i7 6950X OC to 4.5GHz, ASUS RAMPAGE V EDITION 10, Corsair Dominator Platinum 64GB DDR4 2800, SAMSUNG 950 PRO M.2 512GB , GeForce GTX 1080 Founders Edition, Corsair AX1200i PS, Phanteks Luxe Case, 16TB RAID (4)HGST Deskstar NAS 4TB, Corsair H115i CPU Cooler, AJA Kona 4, BMD Intensity Pro 4K, Win 10
GrassValley_PS is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
Manual playout of clips techopsnocsupport GV Edge 1 08-05-2016 03:32 AM
Edius Playout Card Mike Truly EDIUS: Compatible Hardware and Accessories 14 01-11-2015 01:24 AM
K2 Connect vs K2 FTP from Source Browser Tomislav S Editing with EDIUS 3 04-21-2011 02:21 PM
How should I remove edge noise (bottom edge) gilbertl ADVC 2 08-04-2008 11:39 AM
Cheap playout solution Aristotelis ADVC 8 01-23-2008 09:32 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
