Go Back   Grass Valley Forums > Integrated Production & Playout > GV Edge
Reply
Thread Tools Display Modes
Old 02-18-2015, 04:19 PM   #1
Matteo MTV
Junior Member
Default Auto-Sizing Font
Hi Roy,
I would like to achive the follow box in channel composer with one unique scene parameter attached to a unique text player.
The goal is that, depending on the amount of charachter, the text is getting smaller and fit in wordwrap the box.
Is this doable using some controller?
Otherwise we should approach it by creating an applet that count the amount of characters and set scene parameter values of the font size and probably the autofit-wordwrap property.
Thanks,
Matteo
Matteo MTV is offline   Reply With Quote
Old 12-03-2015, 07:40 PM   #2
alatriste1
Junior Member
alatriste1's Avatar
Default
I'm exactly having the same situation of having the font size
adjusted to a number of characters. Is this doable?
alatriste1 is offline   Reply With Quote
Old 12-03-2015, 11:27 PM   #3
antonsvideo
Senior Member
antonsvideo's Avatar
Default
please explain what you mean and which titler you use
__________________
EDIUS 9 WG with Matrox MXO2, Asrock X99 Extreme 6, Intel Core i7 5960X Extreme Haswell-E 8-Core, Corsair Water Cooling, Nvidia Geforce GTX-980, Samsung 860 Pro SSD for System, 8TB Samsung Raid0 SSD for Video, 3 Pioneer BDR-209 Blu-ray/DVD burners, Hotswap Bay for 3.5" Sata and 2.5" SSD, Fractal Design Arc XL Tower, 32GB DDR4 Ram, Win7 Pro
antonsvideo is offline   Reply With Quote
Old 12-03-2015, 11:28 PM   #4
antonsvideo
Senior Member
Default
Quote:
Originally Posted by Matteo MTV View Post
Hi Roy,
Thanks,
Matteo
wordwrap is easy with vistitle, it is not possible with quick titler
__________________
Old 12-03-2015, 11:53 PM   #5
GrassValley_PS
Moderator
GrassValley_PS's Avatar
Default
Anton , He is in Channel Composer, not EDIUS.
__________________
Main System: i7 6950X OC to 4.5GHz, ASUS RAMPAGE V EDITION 10, Corsair Dominator Platinum 64GB DDR4 2800, SAMSUNG 950 PRO M.2 512GB , GeForce GTX 1080 Founders Edition, Corsair AX1200i PS, Phanteks Luxe Case, 16TB RAID (4)HGST Deskstar NAS 4TB, Corsair H115i CPU Cooler, AJA Kona 4, BMD Intensity Pro 4K, Win 10
GrassValley_PS is offline   Reply With Quote
Old 12-04-2015, 12:06 AM   #6
antonsvideo
Senior Member
Default
oops, brain fade
__________________
Old 12-04-2015, 06:12 PM   #7
alatriste1
Junior Member
alatriste1's Avatar
Default
I tried using "Auto-adjust size to contents" but did not succeed. Any idea?
__________________
FOX INTERNATIONAL
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
Can you help with Chroma and re sizing and layouter JohnAC Editing with EDIUS 12 02-11-2014 12:07 AM
Changing open font to true font for TMP ralphbowman Editing with EDIUS 2 07-10-2009 07:40 AM
Window sizing setting change GuyS Editing with EDIUS 3 04-24-2009 04:23 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
