Go Back   Grass Valley Forums > Integrated Production & Playout > GV Edge
Reply
Thread Tools Display Modes
Old 07-07-2014, 07:02 PM   #1
alex177
Junior Member
Default Picture in Picture
Hi,
I am trying to achieve picture in picture(secondary clip/s over the main clip) video playout on one of our channels. I have created a template with the clip players and given them scene parameters that are populated by the Import Fields on the playlist.
During testing the scene parameter is populated with the Asset ID of the clip(a002321.avf). However the main clip plays out but the PiP-secondary clips don't.
Any suggestion on what I am missing to make this work? Thanks
alex177 is offline   Reply With Quote
Old 07-08-2014, 07:50 AM   #2
GrassValley_RV
Grass Valley
Default
Hi Alex,
Can you check the following?:
  • does the PiP Clip object have a play action at the start of the PiP template?
  • has the mentioned asset been correctly transfered to the /publitronic/objects/mpegves folder on the K2Edge?
If the answers to both these questions are yes then please send me your channel pack and system log files so that I can have a closer look.
My email address is: roy dot vanophuizen at grassvalley dot com
Regards,
Roy
GrassValley_RV is offline   Reply With Quote
Old 07-08-2014, 11:44 AM   #3
alex177
Junior Member
Default
Hi Roy,
Thanks for your reply.
- The Clip player is set on Play.
- The asset is not downloading onto the server.
I have attached a screen shot of the event.
Thanks in advance.
Old 07-09-2014, 03:25 PM   #4
GrassValley_JE
Grass Valley
Default
Hi Alex,
The import field values that you provide in a schedule are interpreted by the automation as plain text values. The asset distribution process will only transfer assets if it knows that a particular text value in an event refers to an asset. As the import field values are intepreted as plain text no asset transfers will occur.
There is an alternative way of using import fields that will trigger the transfer of the PIP assets. It works by using a combination of import fields and the external reference values of the PIP assets. It works as follows (steps in Composer while editing the PIP format):
1. Set the scene parameter(s) for each clip source property to the "import field type" (as before).
2. Then enter the import field name that you will insert in your schedule (again, like before) but be sure to prefix it with "[extref]" (without the double quotes). So, if your import field is called "pip1_source" then the value you specify in the format editor is "[extref]pip1_source".
The [extref] keyword indicates that the import field will contain an external reference to an asset in TX-MAM. At schedule time the value of the "pip1_source" import field is used to look up the id of the asset with an external reference that matches the value of the "pip1_source" import field. By using this approach the automation is able to detect that the import field value references an asset; which in turn will trigger the asset distribution process to transfer the asset to playout.
Using the above solution you should be able to achieve the desired result. If you have any further questions then please contact us again.
Regards,
Jan Roel
GrassValley_JE is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
EDIUS 5.12 3D Picture In Picture Problem pradipdabhi Editing with EDIUS 8 06-27-2010 05:53 PM
Using 3d picture in picture together with changed Video layout Gunnarlowe Editing with EDIUS 5 01-23-2010 12:42 PM
Soft border problem within 3d picture & picture stevenfowlerfilms Editing with EDIUS 7 07-17-2009 04:48 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
