Go Back   Grass Valley Forums > Integrated Production & Playout > GV Edge
Reply
Thread Tools Display Modes
Old 06-20-2014, 02:44 PM   #1
fernando.moreno
Junior Member
Default How to scale down to SD 16:9 text objects and groups with text objects
We are creating Channel Packs with several text objects and groups with animations on them. So far we’ve created the HD objects and templates, and now we have to reproduce the same on the simulcast which is SD 16:9. Is there a way to easily achieve this without loosing quality and without doing everything again?
We first tried to create a group and scale it down to 720x576 but the result was really poor.
Since we have most of the text objects grouped, these group can be resized, but the font size remains in the HD size, so probably this would end up with the same poor result.
Regards,
Fernando
fernando.moreno is offline   Reply With Quote
Old 06-26-2014, 07:31 AM   #2
GrassValley_RV
Grass Valley
Default
Hi Fernando,
You'd have to make copies of your group objects and your templates for the SD variant. Then adjust the font size appropriately to your SD needs. One way of copying the group objects and their templates is by exporting/importing them to/from the prefabs library. Alternatively you could merge the project with itself (with additive merging) as this will automatically create copies of all your objects and templates.
Regards,
Roy
GrassValley_RV is offline   Reply With Quote
Old 07-23-2014, 12:45 PM   #3
fernando.moreno
Junior Member
Default
Hi Roy,
Thanks for the reply. We are playing with it.
Regards,
Fernando
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
3d - overlapped objects moved back and forth in/out of focus Jimbo GV Edge 1 06-05-2014 06:59 AM
xplode 3d objects imagepark Editing with EDIUS 10 05-01-2013 07:15 AM
Loading Images Into 3D Objects COMPLETE VIDEO IMAGE Editing with EDIUS 2 09-18-2007 03:23 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
