Go Back   Grass Valley Forums > Integrated Production & Playout > GV Edge
Reply
Thread Tools Display Modes
Old 05-22-2014, 05:50 PM   #1
Jimbo
Member
Default importing/replacing assets into a project
Hi,
I'm have trouble importing a revised version of animations/stills (probably other types of asset as well, although I haven't noted all of them).
When trying to replace an existing item, I receive an error message and a further message to say no assets have been imported.
My workaround is to close the project, and re-open it, and then try again, which seems to work.
Is this possible to explain where I'm going wrong, or is there a fix in a later version? (we have 1.6.5 here, but as yet we have not had time to test it out)
this problem occurs with our Composer version 1.6.1.
Cheers
Jimbo is offline   Reply With Quote
Old 05-23-2014, 07:39 AM   #2
GrassValley_RV
Grass Valley
Default
Hi Jimbo,
Are you using the windows version of Channel Composer?
Roy
GrassValley_RV is offline   Reply With Quote
Old 05-23-2014, 10:54 AM   #3
Jimbo
Member
Default
Yes.
I think I'm finding the issue if the asset is in use in a template. Removing the .ani or .tga from said template, by selecting another .ani or .tga, and the error doesn't seem to be raised....
Old 05-23-2014, 12:18 PM   #4
GrassValley_RV
Grass Valley
Default
Hi Jimbo,
Yes, this is a known issue present only on windows. Windows does not allow you to modify a file (which includes deleting and renaming) that is currently in use. We're still looking at possible solutions here...
A quick workaround: select a template that does not contain an object that uses the asset, enter and exit Try-out Mode (this releases the lock on the asset file) and then delete the asset.
Roy
Old 02-22-2016, 06:43 AM   #5
ductuan
Junior Member
Default
Sorry because place msg!
Pls help me, about import field in Channel Composer:
I want change [extrexf]pop (type Name) by [x]pop.
Mean, i want type ID, so what is [x].
Thanks very much!!!
ductuan is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
How to re-link a large group of assets back to project? LittleMaster Editing with EDIUS 1 04-09-2014 08:17 PM
importing clips from another project Rast537 Editing with EDIUS 5 04-06-2012 11:23 PM
importing aaf project from Avid johannesj Editing with EDIUS 1 01-12-2011 05:29 PM
Importing a sequence into a project cinnabull Editing with EDIUS 3 09-08-2010 01:12 PM
importing aaf project from Avid johannesj Editing with EDIUS 0 05-22-2008 12:28 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
