Go Back   Grass Valley Forums > Replay Control Systems > Working with K2 Dyno
Reply
Thread Tools Display Modes
Old 11-13-2013, 04:14 PM   #1
Hunt
Junior Member
Default Sending PLs to an External Drive
We get an unspecified error when trying to sending PlayLists to an
external drive via the APP Center using the QuickTime setting.
We are able to send individual clips just not a PL.
Any help would be greatly appreciated!
Thanks!
Hunt is offline   Reply With Quote
Old 11-13-2013, 06:25 PM   #2
GrassValley_OB
Grass Valley
GrassValley_OB's Avatar
Default PL export not yet supported
There are currently two workarounds. One is to baseband record the playlist back to yourself, clip it and Send. The other is (available in Dec.2013) IF you have a Dyno S panel, run EDIUS on the Dyno S panel, and drag the Playlist out of the asset folder onto the Timeline and render either back to the Summit or to the external drive.
If using dissolve transitions between clips in the Playlist, the transition is handled by the FPGA processor and is a render-to-air, not a render-to-file and then play the file. Even when this feature of Flattening a playlist to clip and then export gets code support, the playlist will still only have cuts. From what I can tell, this is slated for Mid-2014.
GrassValley_OB is offline   Reply With Quote
Old 07-09-2014, 10:46 PM   #3
edwardgrey01
Junior Member
Default
Hi, when i tried to send a PL to an external hard drive why it would take much time before external hard drive received it. Sometimes it fails and hang up!
edwardgrey01 is offline   Reply With Quote
Old 07-09-2014, 11:16 PM   #4
GrassValley_OB
Grass Valley
Default
What is the format of the external drive? IF it is fat32, files cannot exceed 4Gig, and are you using USB 2 or 3? I achieve 400mbs on a USB 3 drive.
Also, are large clips able to export fine, but PLs fail?
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
Your advices about external drive murat unal EDIUS: Compatible Hardware and Accessories 7 03-31-2010 08:59 AM
Capture to External Hard Drive Robert Chandler Editing with EDIUS 3 09-09-2008 08:34 PM
External Drive BillBarrett Editing with EDIUS 3 03-20-2008 07:27 PM
Recommend an external drive Gunn Editing with EDIUS 21 02-08-2008 01:57 AM
Which external drive for HD work? triciclo Editing with EDIUS 17 01-28-2008 10:05 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
