Go Back   Grass Valley Forums > Integrated Production & Playout > GV Edge
Reply
Thread Tools Display Modes
Old 10-29-2013, 01:03 PM   #1
Jimbo
Member
Lightbulb Composer Format editing
Hi,
When entering data into formats within GV Composer, by clicking on the particular field to fill in scene parameter details, whether it's manual text/dynamic reference/import field, etc. - would it be possible for the mouse-click in the field to result in one of the data types being selected (i.e. click and a 'Manual Text' entry window pops up) with the ability to alter the type, becoming an option after that?
I'm finding that the number of mouse-clicks required is far more than it would be if one of the data types (probably "Manual Text" is the most used for me) was selected as a default, rather than always having to choose a type first, before entering the data.
Cheers,
Jim
Jimbo is offline   Reply With Quote
Old 10-30-2013, 01:30 PM   #2
GrassValley_JE
Grass Valley
Default
Hi Jim,
I'm forwarding your suggestion to the product managers for Channel Composer. Adding a default parameter type on clicks could make sense, 'though I'm not sure all users will be happy with a default "manual text" type. Maybe something that could be made configurable.
Regards,
Jan Roel
GrassValley_JE is offline   Reply With Quote
Old 02-23-2016, 11:11 AM   #3
ductuan
Junior Member
Default
Pls help me, about import field in Channel Composer:
I want change [extrexf]pop (type Name) by [x]pop.
Mean, i want type ID when use import field, so what is [x]?
Thanks very much!!
ductuan is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
Best editing format for Edius awp1323 Editing with EDIUS 4 08-22-2013 10:33 AM
mixed format editing with 5.12 RonnieMartin Editing with EDIUS 5 02-03-2010 03:50 PM
Mixed format Editing, How to? Bassman Editing with EDIUS 2 10-23-2008 03:59 AM
Multi format editing in EDIUS, Overview Fred Dwyer Editing with EDIUS 10 04-19-2008 02:38 AM
Format editing advice! 3chip Editing with EDIUS 5 02-10-2008 12:27 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
