Go Back   Grass Valley Forums > Replay Control Systems > Working with K2 Dyno
Reply
Thread Tools Display Modes
Old 08-27-2012, 06:03 PM   #1
GrassValley_OB
Grass Valley
GrassValley_OB's Avatar
Default Switcher vs Editor Model in Playlist editing
Imagine that you just did a camera cut on your router. You want to use every frame of video before the cut. In SWITCHER model, the system starts or ends the transition with that first or last frame of the clip, so you will never see the camera cut. In EDITOR model, the system uses additional frames from the guard bands for the transition so that your first or last full frame of video is determined by the IN and OUT points of the clip. Therefore, in Editor model you would see the camera cut as part of the transition.
- NOTE: if using transferred clips in a playlist from another system, make sure you include guard bands as part of the clip transfer if you are planning on using Editor model. Because the system uses guard band frames to make the transition possible, if the guard band was not included as part of the transfer, the clip will sit in “pause” for the duration of the transition and then suddenly play. A simple fix for this is to adjust the IN or OUT point for the clip for as many frames as needed to make the transition possible.
GrassValley_OB is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
p2 playlist import? George Glou Editing with EDIUS 10 06-30-2012 06:13 PM
playlist? girift Editing with EDIUS 4 06-26-2009 07:01 PM
Confused by ADVC110 model numbers! randygreen ADVC 2 01-26-2009 09:03 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
