Go Back   Grass Valley Forums > Converters > ProCoder
Reply
Thread Tools Display Modes
Old 11-06-2011, 09:43 PM   #1
nath
Senior Member
Default ProCoder 3, codec CDVC not playing back under Advanced setting
NOTE: codec CDVC is the Canopus DV codec (cdvccodc.dll 6.0.0.10)
This is so strange ... I just installed PC3 and tried about everything possible to get the "Advanced ..." tab to play back these files, so I can perform some minor edits at the beginning and the end of these huge files. All I am getting is a blank screen, and clicking on the "Video Filter" tab I get "Can't render preview" under "Original"
I have Edius 6 installed, and have had PC2 before installing PC3. I uninstalled PC2, installed PC3 3.591 and upgraded to 3.6, then tried a "repair" of PC3, then an uninstall, then a reinstall ... and still no go? (restarted each time between these steps.)
The preview during an export is working?!? Strange.
Any other ideas would be very much appreciated!
nath is offline   Reply With Quote
Old 11-08-2011, 12:00 AM   #2
GrassValley_BH
Demystifier/Analogizer
Default
Is the ProCoder dongle inserted?
The export preview shows video prior to compression - it doesn't use the Canopus DV codec.
Also make sure you don't have any "codec packs" (K-Lite, etc) installed - those often break things.
GrassValley_BH is offline   Reply With Quote
Old 11-08-2011, 12:13 AM   #3
GrassValley_SL
Moderator
GrassValley_SL's Avatar
Default
If it fails with Brandon his advice maybe you can try the following:
1 install Procoder with update
2 install EDIUS 6.05 after.
Now check if it works.
I just checked and on 2 systems here I have Procoder working without an issue.
__________________
GrassValley_SL is offline   Reply With Quote
Old 11-08-2011, 07:30 PM   #4
nath
Senior Member
Default
Quote:
Got the PC3 dongle inserted
these are all my codes:
Audio Codecs
Type Name Format Binary Version
ACM Microsoft IMA ADPCM CODEC 0011 imaadp32.acm 6.1.7600.16385
ACM Microsoft CCITT G.711 A-Law and u-Law CODEC 0007 msg711.acm 6.1.7600.16385
ACM Microsoft GSM 6.10 Audio CODEC 0031 msgsm32.acm 6.1.7600.16385
ACM Microsoft ADPCM CODEC 0002 msadp32.acm 6.1.7600.16385
ACM Fraunhofer IIS MPEG Layer-3 Codec (decode only) 0055 l3codeca.acm 1.9.0.401
ACM Messenger Audio Codec 028E sirenacm.dll 15.4.3508.1109
ACM Ulead MP3 Codec v1.0.18 0001 ulmp3acm.acm 1.0.18.0
ACM Ulead DV Audio Codec 0216 dvacm.acm 8.0.0.0
ACM Microsoft PCM Converter 0001 ulmp3acm.acm 1.0.18.0
DMO WMAudio Decoder DMO 0160, 0161, 0162, 0163 WMADMOD.DLL 6.1.7601.17514
DMO WMAPro over S/PDIF DMO 0162 WMADMOD.DLL 6.1.7601.17514
DMO WMSpeech Decoder DMO 000A, 000B WMSPDMOD.DLL 6.1.7601.17514
DMO MP3 Decoder DMO 0055 mp3dmod.dll 6.1.7600.16385
Video Codecs
ICM Microsoft RLE MRLE msrle32.dll 6.1.7601.17514
ICM Microsoft Video 1 MSVC msvidc32.dll 6.1.7601.17514
ICM Microsoft YUV UYVY msyuv.dll 6.1.7601.17514
ICM Intel IYUV codec IYUV iyuv_32.dll 6.1.7601.17514
ICM Logitech Video (I420) i420 lvcodec2.dll 13.25.1014.0
ICM Toshiba YUV Codec Y411 tsbyuv.dll 6.1.7601.17514
ICM Cinepak Codec by Radius cvid iccvid.dll 1.10.0.13
ICM DVCPRO 50 CDV5 cdv5codc.dll 6.0.0.10
ICM Canopus Lossless CLLC cllccodc.dll 6.0.0.10
ICM Canopus HQ CUVC cuvccodc.dll 6.0.0.12
ICM Canopus DV CDVC cdvccodc.dll 6.0.0.10
ICM DVCPRO HD CDVH cdvhcodc.dll 6.0.0.10
ICM Canopus MPEG2-Intra CMIC cmiccodc.dll 6.0.0.9
ICM Canopus HQX CHQX chqxcodc.dll 6.0.0.9
ICM Canopus C210 C210 c210codc.dll 6.0.0.9
DMO Mpeg4s Decoder DMO mp4s, MP4S, m4s2, M4S2, MP4V, mp4v, XVID, xvid, DIVX, DX50 mp4sdecd.dll 6.1.7600.16385
DMO WMV Screen decoder DMO MSS1, MSS2 wmvsdecd.dll 6.1.7601.17514
DMO WMVideo Decoder DMO WMV1, WMV2, WMV3, WMVA, WVC1, WMVP, WVP2 wmvdecod.dll 6.1.7601.17514
DMO Mpeg43 Decoder DMO mp43, MP43 mp43decd.dll 6.1.7600.16385
DMO Mpeg4 Decoder DMO MPG4, mpg4, mp42, MP42 mpg4decd.dll 6.1.7600.16385
Do not really want to touch Edius 6 install at this time ... can't afford things getting worst.
Old 11-08-2011, 07:34 PM   #5
nath
Senior Member
Default
Thanks for checking on your other systems!
Are you suggesting uninstalling everything first? Edius install files are sitting in the same temp directory as the PC3 files ...
Old 11-10-2011, 06:06 PM   #6
GrassValley_BH
Default
Your codec list looks okay.
It could also possibly be just a failure to create the playback window, rather than a failure of the codec to decode it. Try rendering a Windows Media file and see if you can play that in ProCoder.
If not, it's an overlay thing. Though the fact that you see the preview output tells me it's probably not, but still good to check.
Old 11-14-2011, 07:33 PM   #7
nath
Senior Member
Default
OK - today I uninstalled everything. Resinstalled ProCoder 3 (last version) and, after that, Edius (last version) ... and it is still not giving me video in the Advanced window.
I also tried running it as Administrator, but that did not make a difference.
I rendered a Windows Media file and it is playing in the Advanced option, just like H.264 files and DVSD encoded files are, but not CDVC encoded files? Strange.
Not sure what an overlay thing would be ... Any hint on how to check for that? Thanks ...
Old 11-14-2011, 08:56 PM   #8
GrassValley_BH
Default
Do the CDVC-encoded files play back in Windows Media Player?
Old 11-15-2011, 10:20 PM   #9
nath
Senior Member
Default
Yes - these files play back just fine in Windows Media Player, but not in ProCoder 3 (I do have a copy of ProCoder 2 somewhere, should I try installing it on a different PC and see if I can play that same file back with ProCoder 2?)
Old 11-15-2011, 10:55 PM   #10
GrassValley_BH
Default
If it plays in Windows Media Player then it shouldn't be a codec issue.
You have me stumped.
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
What is the best codec to use for playing back in Windows Media Player dpcam Editing with EDIUS 16 01-19-2011 01:46 PM
Advanced setting exporter plug-in greyed out Mick Jenner Editing with EDIUS 4 01-22-2009 12:28 PM
CDVC Codec download? derekg Editing with EDIUS 2 01-14-2009 05:11 AM
VC-1 Advanced Profile WMV in Procoder enriquelondaits ProCoder 2 08-29-2007 02:35 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
