Go Back   Grass Valley Forums > Converters > FIRECODER Blu & Pegasus
Reply
Thread Tools Display Modes
Old 02-07-2011, 11:12 AM   #1
shueardm
Senior Member
Default Spurs Engine TVMW5 Encore Presets (level 4.1)
I have some presets on Level 4.1 H.264 that I have made with success. (L 4.1 means higher bitrate than previous maximum of 24Mbs)
I have only tested the 50i and the 23.976P presets with a run time of half hour. All work in Adobe Encore CS5 without re-encoding and built to image. The 60i ones shouls also work, let us know if not. Haven't done 720P yet.
Also tested with DVD architect 5.02 (fine)
Note: Not tested in any other version of Encore than CS5. It also takes some time to import (like normal). Not tested with TMP 4 xpress, this is version 5 presets.
Note: May not 100% fully BD compliant because does not work in DVDit PRO HD.
Note: These are all CBR - You may change to VBR, just make the maximum bitrate within 1.5x of the average bitrate.
Let me know how you go.
Footnote: I was told by Grass Valley (some time ago) that the FireCoder Blu was not even capable of doing Level 4.1 H.264 because of Toshiba's implementation. I guess that was smoke and mirrors to get me of their back!! When will Grass Valley take responsibility for this product and give us some proper software integration.
File Type: zip SpursEngine TVMW5 H264 Standard Def BD.zip (19.0 KB, 65 views)
__________________
VIDEODESK AUSTRALIA http://videodesk.com.au
shueardm is offline   Reply With Quote
Old 02-07-2011, 11:34 AM   #2
tony
Senior Member
Default
Mark, these are faster presets compared to the other ones you posted. a lot faster.
__________________
Tony
Asrock Z68 Extreme7 --i7-2700K --EDIUS 8.5WG--HDStorm+ --16GB Kingston HyperX--GTX 560Ti--AX850 PSU--MxM PCI-e Reader--Win 10 Pro 64bit
tony is offline   Reply With Quote
Old 02-07-2011, 11:37 AM   #3
shueardm
Senior Member
Default
Quote:
Yes, the x264wil be a lot better though.
The Spurs Engine shouldn't be used for mastering important jobs, just private or small paid local jobs.
Speed wise, it's half of realtime compared to overnight job
__________________
Old 02-07-2011, 11:40 AM   #4
tony
Senior Member
Default
Its telling me 7hrs to encode 2hrs 25mins, thats a lot faster compared to 21hrs +
UPDATE: now saying 8hrs +
__________________
Tony
Old 02-07-2011, 11:47 AM   #5
shueardm
Senior Member
Default
It comes down if you wait a bit, it should take around 1.5 hours to complete.
__________________
Old 02-07-2011, 11:49 AM   #6
tony
Senior Member
Default
OK Mark, I'll let it work away.
__________________
Tony
Old 02-07-2011, 11:52 AM   #7
shueardm
Senior Member
Default
That is a massive run time for a first test. It will take an hour to import to Encore as well.
Why not cancell and try a 20 minute version.
What source have you got BTW?
__________________
Old 02-07-2011, 12:02 PM   #8
tony
Senior Member
Default
I think you right Mark, 20 mins is enough, When I used the full Timeline to compare I new the exact encoding times in my tests.
My source is a canopus HQ Fine from my HD Edius5 timeline.
__________________
Tony
Old 02-07-2011, 02:27 PM   #9
tony
Senior Member
Default
That canopus HQ avi took 1hr 30min to encode, longer than I thought.
__________________
Tony
Old 02-07-2011, 08:31 PM   #10
Ron Evans
Senior Member
Default
I just did a 1 hour 45min HQ fine file to AVC elementary stream video file using Spurs plugin with TMPGenc 4 Xpress, Level 4.1, 30,000max, 25,000 average VBR . It took just about 55mins on my PC. File is named mvp which I change to .avc which DVD Architect is happy with. Audio is processed separately.
Ron Evans
__________________
Ron Evans
Threadripper 1920 stock clock 3.7, Gigabyte Designare X399 MB, 32G G.Skill 3200CL14, 500G M.2 SATA OS, 500G EVO 850 temp. 1T EVO 850 render, 6T Source, 2 x 1T NVME, MSI 1080Ti 11G , EVGA 850 G2, LG BLuray Burner, BM IP4K, WIN10 Pro
ASUS PB328 monitor, BenQ BL2711U 4K preview monitor, EDIUS 9.5 WG, Vegas 17, Resolve Studio 16
Ron Evans is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
Spurs Engine with FCB John Lewis FIRECODER Blu & Pegasus 16 02-04-2011 08:39 AM
Will Leadtek Spurs card work with Neo? Larry FIRECODER Blu & Pegasus 9 06-17-2010 07:38 PM
PC3 Bluray presets DON'T work with Encore mattmatt ProCoder 9 06-24-2008 09:11 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
