Go Back   Grass Valley Forums > Editors > Editing with EDIUS
Reply
Thread Tools Display Modes
Old 09-13-2010, 10:08 AM   #1
Jim N
Senior Member
Jim N's Avatar
Default The Edius HQX Codec
Edius 6 has obviously been a significant project for GV with many improvements including the HQX codec. This 10 bit variable resolution/data rate codec is the beating heart of Edius's next generation architecture. I would like to know more about this important feature and the advantages it confers.
Jim
Jim N is offline   Reply With Quote
Old 09-13-2010, 05:41 PM   #2
Alter Ego
Senior Member
Alter Ego's Avatar
Default
Quote:
Originally Posted by andrew_hd View Post
It looks like GV has removed Lossless codec from Edius 6, because of new (even better quality) HQX codec. Lossless is missing in the version which they show at IBC.
Will Edius 6 still be able to read and work with files previously created with Canopus Lossless? Is it just a matter of still having the codec installed on the machine? I have tons of files rendered to the Lossless codec.
__________________
Tom Koveleskie - Director/Producer/Editor
Quarter Town Films - Independent Feature and Documentary Films.
Edius 8 WG with HDSpark, AMD 8 core FX 8370 Black Edition 4.3 GHZ, MSI 970A Krait Edition, 16 GB Patriot DDR3 1333 MHz RAM, EVGA Nvidia GTX 780 TI graphics, Win 10 X64.
Alter Ego is offline   Reply With Quote
Old 09-13-2010, 05:45 PM   #3
Senior Member
Jerry's Avatar
Default
Same as other intermediate codecs (Cineform, DNxHD), but this version allows you to go down with quantization to 0, so it means at this setting it will be close or maybe even lossless. It looks like GV has removed Lossless codec from Edius 6, because of new (even better quality) HQX codec. Lossless is missing in the version which they show at IBC.
With modern machine you can have 4k 10bit HQX file with few filters playing with no rendering- quite impressive.
Andrew
Keep in mind that you had better have some serious power to add filters and edit in RT.
Also, you notice the buffer drops from SD to HDV to Full HD, and then 4k....it will take a big hit.
__________________
Main System: Azrock Z97 Extreme 6, 4790K@4.7Ghz, 32gb ram, Corsair H110, Win10 Pro 64, Samsung 850 pro, E7.5/8.5/E9 on separate SSD drives, HD Spark, Intensity Shuttle, 12tb RAID 0 on backplane ,2 BD, Benq 27 and Hanns-G 28 monitors, CC 2019, GTX 1080ti SC Black.
Both systems on Gigabit network
Second System: EditHD Ultimax-i7, X58, 980x@3.74, Corsair H80, Win764, 24gb ram, Storm 3g, Samsung 840 Pro 256, 4tb and 6tb RAID 0 on backplane, GTX 980ti Classified, Edius 9, Apple 30", Samsung 24", dual BD.
Jerry is offline   Reply With Quote
Old 09-13-2010, 11:11 PM   #4
caminostereo
Senior Member
caminostereo's Avatar
Default
Here are more technical information on HQX:
http://translate.googleusercontent.c...fYwwrQ-lxzd0WA
__________________
CSXD2 l For EDIUS Pro 6.5
caminostereo is offline   Reply With Quote
Old 09-13-2010, 11:53 PM   #5
rando
Senior Member
Default
What about the compression VS HDV? ie gigs per hour or drive space?
__________________
Randy
rando is offline   Reply With Quote
Old 09-14-2010, 03:54 AM   #6
rando
Senior Member
Default
yes I know about quality VS space and speed I was wondering how it compares to Canopus HQ in file size. Right now Canopus HQ is about 4-5X the size of HDV or AVCHD is the new CODEC about the same or will it require more space than the current Canopus HQ.
__________________
Randy
Old 09-14-2010, 04:38 AM   #7
gdame
Senior Member
gdame's Avatar
Default
I would say larger through simple math.
1440x1080 HDV ------>8 bit HQ = approx. 5X larger file
1440x1080 HDV ------>10 bit HQX = even larger file (more data = larger file)
These are both I frame intermediary codecs that offload CPU burden in exchange for editing performance with an increase in storage burden. As Andrew mentioned, hard drives for 150Mb/sec video are inexpensive. Making it a very clear advantage.
Jerry and I had a project setup at 3840 x 2160 with a red file that was converted to HQX. It played back perfectly. Real time effects will be a different story as I thing the buffer was maybe in single digits. Actually I think it was 12 or 16. Jerry will chime in at some point and clarify our findings.
__________________
George Dame
gdame is offline   Reply With Quote
Old 09-14-2010, 12:15 PM   #8
Senior Member
Jerry's Avatar
Default
I was able to get this file to play on a Core 2 duo extreme
running at 3.3. The buffer was indeed at 16 and I did not
add any filters. A dissolve required rendering in order
to play. A 980 should be able to play it with the dissolve
easily.
I still prefer to use either HQ, HQX, or AVC-Intra.
These are all I frame based codecs and will have
larger file sizes, but will have the best editing response.
Drive space is cheap. I recently added 6tb for around $300.
__________________
Old 09-14-2010, 04:37 PM   #9
Andreas_Gumm
Senior Member
Andreas_Gumm's Avatar
Default
easily.
Another option could be using the proxy option for limited workstation performance!
__________________
Andreas Gumm
post production / authoring
Windows 7 Ultimate,
GV hardware: 3G Storm
PC 2
GV hardware: HD SPARK
Andreas_Gumm is offline   Reply With Quote
Old 11-18-2010, 09:46 PM   #10
baddgsx
Senior Member
baddgsx's Avatar
Default
hi ,
im new to the HQX codec. I will be capturing hdv. From what I read here HQX at 150mbit or better is what i should capture to. So the higher the quality the easier Edius will run but the larger the files right?
I used to use capture with cineform to avi and import to vegas.
Thanks,
Chris
baddgsx is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
Edius to FCP...what codec? iibw Editing with EDIUS 2 06-08-2010 03:35 AM
CODEC to capture with in edius fersonjames Editing with EDIUS 11 05-19-2010 02:32 AM
HDSTORM HQX-E1 with Edius 4? zvit Editing with EDIUS 1 08-03-2009 04:18 PM
loading a new codec into Edius 5? burnandreturn Editing with EDIUS 16 02-14-2009 04:45 PM
Edius codec via hardware? montage Editing with EDIUS 1 06-23-2007 01:01 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
