Go Back   Grass Valley Forums > Converters > FIRECODER Blu & Pegasus
Reply
Thread Tools Display Modes
Old 03-30-2009, 03:32 PM   #1
stanleychow
Member
Default is FireCoder Blu accerlate encoding only with FireCoder Writer?
i just have an FCB but actually i don't know much about it. How does FCB accerlate encoding? How can i know FCB accerlate encoding? is it only work together the bundled FireCoder Writer? is there any other software which will work with FCB card? i know that Edius 5 will work with FCB later, but before that, only FireCoder Writer is the only solution?
Many thanks!
stanleychow is offline   Reply With Quote
Old 03-30-2009, 04:17 PM   #2
GrassValley_KH
Mr Sparkle
Default
FIRECODER Writer and AVCHD2HQ are the only two applications that make use of the hardware at this time.
GrassValley_KH is offline   Reply With Quote
Old 03-30-2009, 06:17 PM   #3
burnandreturn
Senior Member
Default
So does that mean that the FCB doesn't get used with AVCHDPRV? I was thinking to buy a FCB to view ACVHD files off loaded from camera SDHC card to hard drive on computer and view the video imediately and not use the camera.
I read here that a PS3 would play the files streamed to it but for not much more money I could buy the FCB and have a encoder also.
burnandreturn is offline   Reply With Quote
Old 03-30-2009, 06:35 PM   #4
GrassValley_KH
Mr Sparkle
Default
My bad - when I said "AVCHD2HQ" I was referring to both tools - the previewer and the converter can both use FIRECODER Blu for decoding streams via hardware.
Old 03-30-2009, 06:36 PM   #5
SRsupport
Grass Cutter Gold
SRsupport's Avatar
Default
AVCHD PRV uses the Firecoder BLU. That's why the settings are there. :)
__________________
SRsupport is offline   Reply With Quote
Old 03-30-2009, 09:21 PM   #6
NakedEye
Senior Member
NakedEye's Avatar
Default
I think it is a great idea to buy an FCB especially for encoding your streams....however untill you do buy one why not try VLC Media Player if you just want to preview your AVCHD files pre conversion.....it also freeware.
Just a thought
Dave.
__________________
www.nakedeyedv.com
NakedEye is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
Problem to output to Media with Firecoder blu sitosson FIRECODER Blu & Pegasus 4 01-20-2009 07:08 PM
FIRECODER WRITER v1.02 Beta release GrassValley_KH FIRECODER Blu & Pegasus 0 01-19-2009 05:57 PM
FIRECODER Blu, and encode times Imagine Video FIRECODER Blu & Pegasus 23 12-11-2008 01:13 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
