Go Back   Grass Valley Forums > Editors > Editing with EDIUS
Reply
Thread Tools Display Modes
Old 04-08-2019, 06:24 PM   #1
GrassValley_SL
Moderator
GrassValley_SL's Avatar
Default Edius @ nab 2019
EDIUS@NAB 2019 Canon booth. Waiting for show opening.
__________________
GrassValley_SL is offline   Reply With Quote
Old 04-08-2019, 08:59 PM   #2
GrassValley_SL
Moderator
Default
Prores export
__________________
Old 04-08-2019, 11:18 PM   #3
GrassValley_PS
Moderator
GrassValley_PS's Avatar
Default
No multican audio sync in this version. I don't think it will be ready for the release in May, but if not, it should be shirtly after that. HOWEVER, this is what the NEW UI looks like for it. Note the Audio is greyed out.
You select the number of clips you want to use in multican, right click and select your sync, and a new sequence will open in multican mode, ready edit.
__________________
Main System: i7 6950X OC to 4.5GHz, ASUS RAMPAGE V EDITION 10, Corsair Dominator Platinum 64GB DDR4 2800, SAMSUNG 950 PRO M.2 512GB , GeForce GTX 1080 Founders Edition, Corsair AX1200i PS, Phanteks Luxe Case, 16TB RAID (4)HGST Deskstar NAS 4TB, Corsair H115i CPU Cooler, AJA Kona 4, BMD Intensity Pro 4K, Win 10
GrassValley_PS is offline   Reply With Quote
Old 04-08-2019, 11:34 PM   #4
johannesj
Senior Member
Default
Quote:
Originally Posted by GrassValley_SL View Post
Prores export
WHAT?? Say again!!!!
__________________
JoiCam´s
Edit station1: i7 6700K 4 ghz, 32gb ram, Edius 9 Workgroup, Davinci Resolve studio 14.x , 8GB GPU & Intensity Pro 4K
And more
johannesj is offline   Reply With Quote
Old 04-09-2019, 12:28 AM   #5
GrassValley_SL
Moderator
Default
Yep on Windows.:)
__________________
Old 04-09-2019, 12:35 AM   #6
GrassValley_PS
Moderator
Default
Also Prores Raw. BM RAW is being worked on
__________________
Old 04-09-2019, 01:23 AM   #7
GrassValley_PS
Moderator
Default
EDIUS 9.4 What's new
__________________
Old 04-09-2019, 07:04 AM   #8
STORMDAVE
Senior Member
Default
Aw that’s that’s sad :(
Hopefully it comes by November.
STORMDAVE is offline   Reply With Quote
Old 04-09-2019, 11:10 AM   #9
johannesj
Senior Member
Default
The Prores Raw and Blackmagic Raw import and Prores 422 export with out the need of using Fusion Studio are a big game changer for me. I want it now :)
Looking forward to it.
__________________
JoiCam´s
And more
Old 04-09-2019, 11:34 AM   #10
editon
Member
Default
When will it be available?
__________________
ASRock Z170 Extreme7+, Intel Core i7-6700K, GTX 970, 32 MB DDR4 Skill, Blackmagic Intensity 4k, W10, Edius 9 Workgroup
editon is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
EDIUS Get Together NAB 2019 GrassValley_SL Editing with EDIUS 13 04-13-2019 06:26 PM
Sapphire 2019 not working with EDIUS 8 abdolrahman EDIUS: Compatible Third Party Products 3 03-25-2019 01:51 AM
NAB 2019 GrassValley_Admin Grass Valley News and Events 0 03-22-2019 10:51 PM
NAB 2019 triciclo Editing with EDIUS 1 02-27-2019 10:09 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
