Go Back   Grass Valley Forums > Editors > Editing with EDIUS
Reply
Thread Tools Display Modes
Old 07-26-2007, 08:28 PM   #1
tarkken
Member
Default Recommended project settings for DVCPRO 1080 24/30p and 720 240/30p?
Hello.
Working with the new HPX2000 camera, and venturing into the 24/30p recording capabilities (both 1080 & 720 modes).
The camera can not currently record progressive native (pN) - although it should at the beginning of August with firmware (or you can with the FS100 v3). That being said, I believe when you record 24 or 30p, you're recording the stream with pulldown added.
What project settings do you recommend when editing/finishing a project in DVCPRO HD 24/30p (Edius SP 4.24), assuming that pulldown is already added to the file?
Is there a recommendation to remove pulldown before/after editing prior to putting it on the edit timeline, or exporting DVD? What is the recommendation for doing that (inverse telecine via Procoder 3)? I believe that other programs have 'remove pulldown' options, etc.
Just wanted to confirm the flow/recommendations. It seems like I'm getting significant 'stutter' on pans in 24/30p. I know that you have to respect pans and quick motion in these framerates - however, this seems more pronounced and annoying compared to what I'm seeing on TV programs (like American Chopper HD - which I believe is DVCPRO HD 30p). I just wanted to make sure I'm not somehow doing 'double pulldown' - if that's even possible. It doesn't look/feel quite right now - at least with motion involved. I've made sure that my shutter is 1/48 for 24p & 1/60 for 30p.
Thought I'd bounce this out there.
tarkken is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
