Go Back   Grass Valley Forums > Editors > Editing with EDIUS
Reply
Thread Tools Display Modes
Old 04-26-2017, 10:07 AM   #1
Romigo
Senior Member
Romigo's Avatar
Default Is it possible Drug drop clips from Edius Bin to Mync Catalogue
Is it possible Drug drop clips from Edius Bin or Timeline window to the Mync window or catalogue or storyboard ?
It will make this much more ussable.
Its only about 3 variables: File path, TC in, TC out or Duration.
Sometime I need to use some edited clips from other old project.
I cant import it as a sequence because it was made in 50i. New project is 50p.
Romigo is offline   Reply With Quote
Old 04-26-2017, 11:53 AM   #2
GrassValley_SL
Moderator
GrassValley_SL's Avatar
Default
You have access to every clip and storyboard in Mync trough the EDIUS source Browser.
__________________
GrassValley_SL is offline   Reply With Quote
Old 04-26-2017, 02:21 PM   #3
Romigo
Senior Member
Romigo's Avatar
Default
Yes, I found it, but is it possible in the oposite direction ? Edited clip with from EDIUS bin to Mync ?
Drug and drop is more intuitive :)
Old 04-26-2017, 02:34 PM   #4
GrassValley_SL
Moderator
Default
Maybe you can export the edit pieces which you need to a folder?
This way yoi archive the edited clips you think you will need.
__________________
Old 04-27-2017, 01:31 AM   #5
GrassValley_PS
Moderator
GrassValley_PS's Avatar
Default
If it is an original clip, you should already be able to see it. If it is a clip that is being " created" in EDIUS, Mync should be able to see the exported location
__________________
Main System: i7 6950X OC to 4.5GHz, ASUS RAMPAGE V EDITION 10, Corsair Dominator Platinum 64GB DDR4 2800, SAMSUNG 950 PRO M.2 512GB , GeForce GTX 1080ti SC Black, Corsair AX1200i PS, Phanteks Luxe Case, 16TB RAID (4)HGST Deskstar NAS 4TB, Corsair H115i CPU Cooler, AJA Kona 4, BMD Intensity Pro 4K, Win 10
GrassValley_PS is offline   Reply With Quote
Old 04-29-2017, 10:56 PM   #6
Romigo
Senior Member
Romigo's Avatar
Default
Of course I can export clip. Exporting takes time.
But what I ment: was moving only the the link (file path, TC IN, TC Out)
(that what i see in Bin window) like moving from Bin folder to timeline.
It would be nice to "drug and drop" clips link it freely from Edius to Mync and back.
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
Edius 7.31 adding clips to bin createmedia Editing with EDIUS 0 09-04-2014 02:13 AM
importing canon mxf clips to bin in edius 6.2 jimtrus55 Editing with EDIUS 3 11-12-2011 12:46 AM
Bring Ex3 Clips into Edius Bin tony Editing with EDIUS 6 05-24-2009 11:20 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
