Go Back   Grass Valley Forums > Editors > MYNC
Reply
Thread Tools Display Modes
Old 03-03-2017, 11:46 PM   #1
admasv
Member
Default Mync
is this tool a standalone too so i can install it in edius 7 pc
__________________
1.window 10 pro- edius 9 wg- hd mx02- maximus v extrim i7 3700k -gtx 1070 ti -32 g.b ram-500gb ssd system drive-4 tb hdd
2.window 7 ultimate- edius 6-i3 3400k- hd spark pro -quadro fx 4500-24gb ram-500gb ssd system drive- 1 tb hdd
admasv is offline   Reply With Quote
Old 03-04-2017, 12:47 AM   #2
antonsvideo
Senior Member
antonsvideo's Avatar
Default
you can install it as a standalone on any PC that does not have EDIUS (any version) installed
it comes with EDIUS 8.32 and that is the only way to have it on the same PC as EDIUS
__________________
EDIUS 9 WG with Matrox MXO2, Gigabyte X299 UD4 Pro, Intel Core i9 9960X 16 Core, 32 Threads @ 4.3Ghz, Corsair Water Cooling, Gigabyte RTX-2070 Super 3X 8GB Video Card, Samsung 860 Pro 512GB SSD for System, 8TB Samsung Raid0 SSD for Video, 2 Pioneer BDR-209 Blu-ray/DVD burners, Hotswap Bay for 3.5" Sata and 2.5" SSD, Phanteks Enthoo Pro XL Tower, Corsair 32GB DDR4 Ram, Win10 Pro
antonsvideo is offline   Reply With Quote
Old 03-04-2017, 02:25 AM   #3
Ron Evans
Senior Member
Default
I found that out as it will not install on the PC I have EDIUS 6.08 on or EDIUS 7 either. Sad that I can install on a PC with nothing I assume. I have come to like using the Browser for family stuff makes sorting easy. No use for my projects though as they are simple 4 camera with just 8 clips for the total 2 hours. No sorting needed.
__________________
Ron Evans
Threadripper 1920 stock clock 3.7, Gigabyte Designare X399 MB, 32G G.Skill 3200CL14, 500G M.2 SATA OS, 500G EVO 850 temp. 1T EVO 850 render, 6T Source, 2 x 1T NVME, MSI 1080Ti 11G , EVGA 850 G2, LG BLuray Burner, BM IP4K, WIN10 Pro
ASUS PB328 monitor, BenQ BL2711U 4K preview monitor, EDIUS 9.5 WG, Vegas 17, Resolve Studio 16
Ron Evans is offline   Reply With Quote
Old 03-04-2017, 09:21 AM   #4
John Hooper
Senior Member
Default
AFAIK, Mync Basic is a free download and can be installed as a standalone. This is free for a few months.
Mync Standard which has a few more options is the one that is supplied with Edius.
I am not sure if Mync Basic will install on a system that already has Edius on it, if you remove GV Browser first?
See here:
https://myncworld.com/en/
Download here:
https://myncworld.com/en/download/
__________________
John Hooper is offline   Reply With Quote
Old 03-04-2017, 12:32 PM   #5
Ron Evans
Senior Member
Default
NO it will not install if EDIUS other than 8.32 is present without uninstalling EDIUS. At least that is what the window told me when I tried to install on my PC with 6.08. That of course did not have Browser so no conflict there. I would just like to use instead of PlayMemories.
__________________
Ron Evans
Old 03-04-2017, 12:55 PM   #6
GrassValley_PS
Moderator
GrassValley_PS's Avatar
Default
For versions other than 8, You might try uninstalling EDIUS, install Mync standalone and then reinstall EDIUS. This is strictly unofficial, and I have no idea if it will really work. Try at your own risk.
__________________
Main System: i7 6950X OC to 4.5GHz, ASUS RAMPAGE V EDITION 10, Corsair Dominator Platinum 64GB DDR4 2800, SAMSUNG 950 PRO M.2 512GB , GeForce GTX 1080ti SC Black, Corsair AX1200i PS, Phanteks Luxe Case, 16TB RAID (4)HGST Deskstar NAS 4TB, Corsair H115i CPU Cooler, AJA Kona 4, BMD Intensity Pro 4K, Win 10
GrassValley_PS is offline   Reply With Quote
Old 03-04-2017, 05:54 PM   #7
Ron Evans
Senior Member
Default
I think I will just use the version on my main editor and export the files if needed.
__________________
Ron Evans
Old 05-15-2017, 11:53 PM   #8
KevMull
Member
Default
Why the restriction if you have Edius already installed?
I though it was meant to work in conjunction with Edius?
What is the point of just the browser on it's own/
It's a bit like Adobe saying you can install Bridge but not have Photoshop installed!
KevMull is offline   Reply With Quote
Old 05-16-2017, 12:42 AM   #9
GrassValley_SL
Moderator
GrassValley_SL's Avatar
Default
It works with the version of EDIUS it comes with.
__________________
GrassValley_SL is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
Grass Valley Unveils Mync, a New Personal Content Management Tool Green Grass MYNC 22 03-04-2017 07:27 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
