Go Back   Grass Valley Forums > Editors > EDIUS: Compatible Hardware and Accessories
Reply
Thread Tools Display Modes
Old 03-10-2014, 09:08 PM   #1
hapdigital
Member
Default Reinstall Win7 Need to Reinstall Edius ? ?
Reinstall Win 7 64 after computer failed to reboot and Backup Image and Restore failed. . . I did a new install of Win7 64. Prior to this I was unable to deactivate Edius 6.5. I have access to Windows.old that has the Edius folder intact. Suggestions on how I do a fresh install or transfer the registration folder to the new install of Edius ? ?
Is there anything I should consider during this installation??
hapdigital is offline   Reply With Quote
Old 03-11-2014, 12:29 AM   #2
antonsvideo
Senior Member
antonsvideo's Avatar
Default
it appears you did a repair install since you have windows.old, I don't do repair installs, they are always a mess
if you have no 6.5 activation left (by default you can activate twice), call support and tell them what happened, they will then reset the counter and you can activate
__________________
EDIUS 9 WG with Matrox MXO2, Gigabyte X299 UD4 Pro, Intel Core i9 9960X 16 Core, 32 Threads @ 4.3Ghz, Corsair Water Cooling, Gigabyte RTX-2070 Super 3X 8GB Video Card, Samsung 860 Pro 512GB SSD for System, 8TB Samsung Raid0 SSD for Video, 2 Pioneer BDR-209 Blu-ray/DVD burners, Hotswap Bay for 3.5" Sata and 2.5" SSD, Phanteks Enthoo Pro XL Tower, Corsair 32GB DDR4 Ram, Win10 Pro
antonsvideo is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
Edius 6.5 reinstall? burnandreturn Editing with EDIUS 18 02-15-2014 01:32 PM
Edius Crash and reinstall vortigern Editing with EDIUS 0 04-19-2011 04:42 PM
Edius 6 reinstall vortigern Editing with EDIUS 4 03-05-2011 04:31 PM
reinstall from Edius 5.0 alanlacey Editing with EDIUS 3 05-28-2010 04:12 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
