Go Back   Grass Valley Forums > Editors > Editing with EDIUS
Reply
Thread Tools Display Modes
Old 03-02-2012, 10:09 PM   #1
GodfreyD
Junior Member
Default Template
I can see how to store a revised window layout but is there anyway in Edius 6 to make a template of the window and restore every time the number of timelines we choose?
Each time we start a new project the default basic timelines appear and we would prefer to have a number of video and audio video timleines that we specify.
GodfreyD is offline   Reply With Quote
Old 03-02-2012, 10:38 PM   #2
GrassValley_PS
Moderator
GrassValley_PS's Avatar
Default
Set that up in your Project Preset.
GrassValley_PS is offline   Reply With Quote
Old 03-03-2012, 01:45 AM   #3
antonsvideo
Senior Member
antonsvideo's Avatar
Default
in Edius6, you need to go to system settings, project presets, select the one you wish to modify and modify the number of V, VA, A and T tracks
now go to project settings of your currently open project and you can reapply the template
then next time you start a new project, the correct number of V, VA, A and T tracks will be there for you
__________________
EDIUS 9 WG with Matrox MXO2, Gigabyte X299 UD4 Pro, Intel Core i9 9960X 16 Core, 32 Threads @ 4.3Ghz, Corsair Water Cooling, Gigabyte RTX-2070 Super 3X 8GB Video Card, Samsung 860 Pro 512GB SSD for System, 8TB Samsung Raid0 SSD for Video, 2 Pioneer BDR-209 Blu-ray/DVD burners, Hotswap Bay for 3.5" Sata and 2.5" SSD, Phanteks Enthoo Pro XL Tower, Corsair 32GB DDR4 Ram, Win10 Pro
antonsvideo is offline   Reply With Quote
Old 03-03-2012, 08:49 AM   #4
GodfreyD
Junior Member
Default template
Thanks Anton. Followed advice but after clicking OK having reset the tracks and then retruning to check all was set, I found that the default settings had reppeared. Any suggestions please?
Old 03-03-2012, 01:50 PM   #5
GrassValley_PS
Moderator
Default
Set the project preset like you want. Then close EDIUS. Start a new project and see if the setup is now retained.
Old 03-03-2012, 02:39 PM   #6
GodfreyD
Junior Member
Default Template
Yes the project setting are now altered but opening a new project with the Edius symbol showing goes back to showing the default timeline settings.
So we have
1. Changed the project settings under User
2. Clicked ok and found the edius symbol
3. Clicked on that for a new project and discovered the default settings have reappeared.
What are we missing?
Old 03-03-2012, 02:41 PM   #7
GodfreyD
Junior Member
Default Template
Anton
What do you mean
"now go to project settings of your currently open project and you can reapply the template"
How to" reapply" please?
Old 03-03-2012, 02:42 PM   #8
GrassValley_SL
Moderator
GrassValley_SL's Avatar
Default
You have to do this via system settings-> project presets.
You need to change the top level preset than it will work for all projects .
This ability is also visible when creating new project presets.
In a current project the when adjusted , the new settings take effect in a new timeline (sequence tab ) with the project.
__________________
GrassValley_SL is offline   Reply With Quote
Old 03-03-2012, 02:57 PM   #9
GrassValley_PS
Moderator
Default
As we all have suggested...your mistake is in not changing it in the correct place. Go to Settings>System Settings>Project Settings.
Also note this will not affect your current timeline but will any new ones.
Old 03-03-2012, 03:29 PM   #10
Khoi Pham
Senior Member
Default
Is there anyway you can also make a template for Edius to open with all video and audio tracks expand?
__________________
Khoi Pham is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Similar Threads
Saving a Sequence template for new projects baddgsx Editing with EDIUS 2 11-10-2011 05:59 PM
TMPGEnc5 : create template Marc44 EDIUS: Compatible Third Party Products 8 05-26-2011 09:48 PM
Creating your own project template? EdiReady Editing with EDIUS 1 12-28-2007 09:00 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Forum Jump
