Grass Valley Forums
Grass Valley Forums (http://forum.grassvalley.com/forum/index.php)
-   Editing with EDIUS (http://forum.grassvalley.com/forum/forumdisplay.php?f=7)
-   -   Edius 8.5 issues (http://forum.grassvalley.com/forum/showthread.php?t=39795)
George Glou 05-04-2017 07:45 PM
No Rusty. Nothing unusual. In version 8.3 everything was working perfect. Just after installing the new version this issue came up
antonsvideo 05-04-2017 09:20 PM
Can I see the clip name of the clip prior to the cut, so that I can see both clip names
George Glou 05-05-2017 09:55 AM
1 Attachment(s)
Yes Anton.
Here it is
George Glou 05-05-2017 10:00 AM
OK Something new. The audio level is automatically changes to the previous OR to the next clip's audio level ONLY if I change the audio level from the audio mixer.
So if I change the level with ALT+left mouse clik and then I go to the previous or next clip, then everything is ok.
So it must be something with the Audio mixer.
George Glou 05-05-2017 10:07 AM
1 Attachment(s)
Unforynatelly its not good again. If I change audio level with ALT+mouse click and then I click the next clip and previous again....then audio is also changing.
Its a CHAOS. I dont think I can edit like this.
antonsvideo 05-05-2017 10:34 AM
could you try if this problem goes away when using V+A tracks instead of VA
maybe it is a bug with VA
I don't use VA tracks but will do some testing to see if I can repeat your finding
George Glou 05-05-2017 10:41 AM
In seperately V & A track its still happening ony if I change the level from the audio mixer.
ALT+mouse. is OK
antonsvideo 05-05-2017 11:07 AM
1 Attachment(s)
I tested with VA and can't repeat it, see attached
can you tell me the file size of your clip 00005
if it is 3.99GB than it could be that clip 00006 is a continuation of the same clip that was split by the camera due to the 4GB size limit per clip
btw, why are you dragging the node when moving whole line? you can just drag the line anywhere, no need to try and get mouse pointer on that half cut node
also, normalize clip works a lot better for me than dragging lines, I no longer do that because the volume lines are in the wrong position, they are way too low to the bottom instead of being in the middle
George Glou 05-05-2017 11:20 AM
Each clip is about 20 mb. There are short clips from a wedding car. its about 7 sec.
Sometimes I dont need sound(so I have to lower it) and then if I want to let the groom for example to be heard, then I have to play with the audio level to find out in which level he sounds ok. So I do have to play with the audio bar.
If I intall the previous version of Edius will it cause something bad? Can I do that? Because this audio issue drives me crazy.
antonsvideo 05-05-2017 01:10 PM
yes, you can use the previous version with no harm done to your project
I will do some more testing to see if I can figure out what setting could cause this
