Picture shake stabilizer....
    Originally posted by Bluetongue View Post
    Mercalli does give some queer effects with moderate camera movement like the edges of the lens are made of "Jelly"
    Regards Barry
    that can be hidden by choosing border area: without border upscaled
      Even with that stabilizing walking video can make from the center to the outside look like a jelly, not quite syncronized with the movement of the center
      Regards Barry
        are you using pro or standard?
          Anton - Is there a difference in the control available between the lite and pro versions?
          I have some footage Of 2 people walking ahead of me I am following and although not supposed to be filming - I held the camera and shot some footage.......I captured a real nice moment and would like to use it BUT the proceeding shots are poor - only excessive movement of camera - Focus is fine and overall composition is fine.
          I have tryed to stabilize it with EDIUS PIP but its too much to do - In your experience would I have a chance with the EDIUS plug in MERCALLI
          Sorry for slight hijack - tis on topic though
          Thanks - ! Cath
            I would get the pro version of mercalli, it certainly will fix your shot and it has more settings for the quality of the shake removal than the standard version
            • #21
              Pro
              Hi,
              Go the Pro version of Mercalli, it does have a lot more settings in it to do a lot of custom work.
              Cheers
              • #22
                Thanks - There is a free programme with it to ADD shake - anyone used it for effects?
                • #23
                  I've tried it, but it's kind of weird.
