G'day everyone. On some long telephoto shots, my camera still exhibits some "shake" in the picture. There used to be a couple of third-party programs that would help eliminate camera shake. Anyone know of one that works with EDIUS and HD? Many thanks. Alan
Picture shake stabilizer....
Alan J. Levi
Director
SYSTEM:AsRock Z490 Taichi MB, Intel i9-10850K CPU, 64 Gig Trident 3600 RAM, Corsair HX1000W PS, nVidia RTX 3070 Video, Corsair h115i Water CPU cooler, Asus BW16-B1HT BluRay DVD, Samsung 512GB SSD boot in Swapable Tray, 2 1TB Samsung SSD video files RAID 1, 4.5TB RAID 1 Outboard backups, Behringer 2000 Audio Fader/Controller, LG 27" 4K Monitor, 2 Asus 1080 monitors.Tags: None
Boris FX and RED4:
http://www.borisfx.com/product/fx/
http://www.borisfx.com/product/red/
Get the demo from their site and try if it fits your needs.
You can use Autodesk's Combustion to do the Job...It works just fine for me...However there is not any connection with Edius...You have to render the stabilized project in Combustion and then import the file in Edius to do the final editingAristotelis Bafaloukos
BEng (Hons), MSc, MBCS
Ctrl+Alt+Delete
Here's a video tutorial where you see how to stabilize footage with RED:
http://www.borisfx.com/html/products...r/OptStab.html
After Effects is also excellent for this.
PaulEdius Edits at: http://www.vimeo.com/user781619/videos
Originally posted by AJL14 View PostG'day everyone. On some long telephoto shots, my camera still exhibits some "shake" in the picture. There used to be a couple of third-party programs that would help eliminate camera shake. Anyone know of one that works with EDIUS and HD? Many thanks. Alan
It didn't work too well for me the other day and I had to drop it, but that was very unstable/shaky footage.
But, if as you say, it is 'some shake', try 3DPIP and keyframe it stable there and see what you get.peterC
Edius 9 v3
Hd ??
Thanks, guys. really appreciate the input. However - nowhere on the Boris site do I see that either of their products is capable of handling HD - 1440x1080 video. Especially Boris fx. Even their demos show SD. Any experience with this?
Thanks again, Alan.Alan J. Levi
Director
Mercalli
Hi,
I suppose I better support the company that I do reviews for, Go with ProDad Mercalli, this program is great to fix camera shake.
Cheers
SteveMain system, Supermicro X8DAH+,Dual Xeon X5680 cpu's 24 cores,2x1400watt power supplys,SC747TG-R1400B-SQ Case,192GB 1333mhz ECC Registered ram,8 x 480GB Intel 520 SSD drives,Windows 7 64 bit ultimate, GTX 670 4GB ,2 x Sony BWU300S Blu-Ray burners, 1x Sony DVD burner,LSI 9266 Raid Controller with Cache vault & fast path Lic, ESI MayaE Audio,HD Spark,Blackmagic intensity Pro,TMPGenc 5,Episode Pro 6,Sorenson 9 Pro,Alcohol 120 V2, Edius 6.53,Dell 27"LCD,HD Spark, Powershield 3000VA UPS.
Mercalli actually works well, but with all stabilization software it will exhibit some anomalies that some may find odd or occasionally downright freaky! I think there's a demo available at prodad.de. Worth a look, fer sher!Rusty Rogers | Films
Yes I agree MERCALLI is the way to go, the Boris Red stabilizer does not really work well compared to mercalli. In fact If you probe the Boris site they infer the Motion trackers do not work in Edius, but they do to some extent.
Also requires intensive rendering and "Shift+Q" to give a rendered file on the timeline, then in HD change the interlace to lower field as found by Anton.
Mercalli does give some queer effects with moderate camera movement like the edges of the lens are made of "Jelly"
