Edius5 and Vitascene problem
  • Edius5 and Vitascene problem
    PROBLEM HELP Please...
    I used to work with vitascene on edius 4.60 ... Everything goes fine
    Yesterday i have upgraded to edius 5 and i install the vitascene from the included package...
    now when i make an effect through vitascene and trying to save it as preset it is ok..
    but when i close edius and reopen again me effect is gone ... and i see the blue standart fx only... PLEASE HELP....
    www.anima3dproductions.blogspot.com
    Try removing it and installing the one you had.
    I did not install the one that came with 5, I copied the tpi file from 4 Plug in folder away and then copied it to the Edius 5 Plug in folder and have had no problems, did not have to reinstall the one that came with 5
    Regards Barry
      in the edius 5 when we use vitascene we do not make save we go file in menu and we select
      back to the editing program
        use the plug icon not the diskette icon
        EDIUS: Faster, Better, Stronger, Than all the rest!
          No No you did not understand me...
          I make a custom effect in vitascene... I return to edius using F12. I drug the effect to the presets window of edius an I save it with the name "effect1" , so when i want to reuse this effect I just drug it to the video and works fine without the need to open vitascene again. But when I close edius and reopen it again all my customs effects became the standard Blue vitascene effect... I have never had problems with Edius 4,60.
          Sorry about me english and than you for the replies
            ok, I can confirm the problem as well... I don't remember if edius 4.x had the same behaviour or not since I never tried to save a vitascene preset that way...
            you can always save the preset you want within vitascene... not so fast, but it works fine...
            Aristotelis Bafaloukos
            BEng (Hons), MSc, MBCS
            Ctrl+Alt+Delete
              The problem exists in vitascene transitions too. This is a big problem for me because it slows me down very much... thank you
                This is a known problem and has been reported.
                  There has been problems with Vitascene before it was released to the public, and there still is.
                    This problem has been fixed with their latest update :)
                    GESTOS PRODUCTIONS
                    www.gpvideo.com.au
