Anybody picked these up yet? They look quite useful and appear to work in Edius! No wonder GV is keen on them.
NewBlue Video Essentials
Twain - "Glances at History" 1906Tags: None
All of the functions are already in Edius. It just puts them under one heading.
$79 isn't that bad either. That is, if they work they way they are described.Jerry
Originally posted by Jerry View PostI guess I received the same email that you did Rusty. It does look interesting.
And, unless my EDIUS installation is missing some stuff (entirely possible), there are quite a few filters in here that are unique - Detail Enhancer, Flash Remover, Touch Up and Pixelator being examples.
But, you can always download the trial versions to check them out and decide for yourself.
http://www.newbluefx.com/try.html
One last thing: Try out Color Fixer Plus.
And, please let us know what you'd like to see next. Many of our best suggestion come from customers (flash remover was suggested by a frustrated wedding vidoegrapher, for example.)
Thanks,
Todor
newblue video essentials
hi
i think you have already done well for edius but keep it up and continue to support edius with more plug insThanks
SK Raja
Adobe production suite cs5
windows 7 ultimate 64bit Edius 6 Vitscene Mercalli Bluff Titler Boris FX
I am using them in Edius, These plugins are great and worth getting, great for the wedding Videographer to.
Cheers
SteveMain system, Supermicro X8DAH+,Dual Xeon X5680 cpu's 24 cores,2x1400watt power supplys,SC747TG-R1400B-SQ Case,192GB 1333mhz ECC Registered ram,8 x 480GB Intel 520 SSD drives,Windows 7 64 bit ultimate, GTX 670 4GB ,2 x Sony BWU300S Blu-Ray burners, 1x Sony DVD burner,LSI 9266 Raid Controller with Cache vault & fast path Lic, ESI MayaE Audio,HD Spark,Blackmagic intensity Pro,TMPGenc 5,Episode Pro 6,Sorenson 9 Pro,Alcohol 120 V2, Edius 6.53,Dell 27"LCD,HD Spark, Powershield 3000VA UPS.
Hea Todor,
I'm checking out the Video Essentials and trying to get a grip on what may be the only feature I'm interested in... the Flash Remover.
Install went perfectly, but I see no effect on my "flashed" subject? Is this correct, or did I miss something?
>edit<
Yes, I did miss something, the Threshold must be lower for bright flashes! Quite the opposite I expected from the "Bright" preset. (I guess the presets refer to the ambient lighting.)
I think I see another problem... Noise Reducer is not available, instead Pixelator is there in place of Noise Reducer (twice!)
Flash Remover looks so good I may spring for this soon!Last edited by Rusty; 09-25-2008, 10:42 PM.Rusty Rogers | Films
Hey Rusty,
Thanks for catching our "Oops". We also had an effect called Noise Reducer which does noise reduction. However, we just weren't happy with the results and felt it would better not to include it unless we felt really good about it. So, at the last minute we removed it. Unfortunately, in the build process, an old copy of the plugin was still there and made its way into the install, like an angry ghost back to haunt us! It's Noise Reducer only in name because Noise Reducer really is gone and so it points to the same place in our essentials dll as does Pixelator. However, you aren't missing anything.
We will have that gone in a slipstream release any day now. It's harmless, but nevertheless annoying.
As for Flash Remover, I agree... We need to work on the presets. I always find I need to turn it way down too. I'm glad you like it - we're already getting raves about it and Color Fixer from users.
Thanks,
Todor
Ok...
But is Noise Reducer dead at this point or still a work in progress? Many seem to need it.
Anton wants a "Perfect HD to SD Plug-in". Can you make that? I hear he's in the market.Rusty Rogers | Films
Sorry - that wasn't much of an answer!
Thanks,
Todor
Hea Todor...
I'd really like Flash Remover to work on Progressive footage, but all I get is what looks like a smear during the flash. Is this correct?
Interlaced seems to work better.
Am I missing something?Rusty Rogers | Films
Thanks,
Todor
NewBlue Essentials - Edius 4.6 Crashing
We bought Essentials and the color fixer does a great job. My problem is that Edius has crashed 4 times today and has crashed 0 times over the last year. We get a Windows "Sorry Edius must be shut down" type of message. This is an SD project with two video tracks and 4 audio. There are no audio VSTs installed in Edius. Thus far, this project has no effects on the audio.
Windows XP Pro SP3, Dual Xeon 3.4 ghz, 4 gigs RAM, Quadro FX1300, NX PCI-X, Edius 4.6. All the latest drivers and Windows updates are installed.Main Edit Station: Edius 6.02, Gigabyte UD5, i7-950 @ 4.0, GTX 470, 12 GB GSkil, HD Spark, 4 TB RAID0 WD RE Video Drive, 2 TB RAID0 Render Drive
2nd Computer: Edius 6.03, Asus P6X58D-E, i7-950 @ 3.07, Radeon 2600, 6 GB Corsair, 1.5 TB RAID0 Video Drive
I have just bought the essential plugins. I' have tried to use it with an underwater clip with some flash inside (the clip have a strong blu dominance) but without any success... Using it at the minimum thresold generate a poor video quality with frame drop. But the most problematic is the stability of the plugins, my Edius 5.01 crash very often...
Daniele
Italy
