Pssst Hans - I have already set the files to be hosted off these very forums. :)
" Cinema Suite 3.0 " / 65 Presets Look ( Edius )
This topic is closed.
Originally posted by vienna1944er View PostThanks, from europe\austria\vienna.........Great work.......
in the past the one or other user have problem's with the ".rar" file
therefore transfered to ".zip" ..........for extract with only the "windows" tool......
friendly greetings from the "inhouse-librarian" ....... old (but not morbid) Hans ;-)
PS: I hope, this is okay, .....if it is undesired \ banned.... I have the "delete-link" to this both files......Last edited by caminostereo; 06-05-2008, 04:30 AM.CSXD2 l For EDIUS Pro 6.5
Dear caminostereo..... please excuse.....both files are immediately deleted on the Server.....
about the "click and wait" procedure >> if you (or anyone) need a free upload server with max 100MB, file aviable for 1 year
http://www.file-upload.net/ = uncomplicated \ no wait time \ need no e-mail adress \ need no log in
and it replay the "download-link" and "delete this file-link" ...... additional as option is a "commentar" to the file aviable
@ Kenneally Harder ...... okay I have to expand my singnature with the word "blind"
friendly greetings from europe\austria\vienna ....... old, blind (but not dead) Hans ;-)Edius 5,51 / Edius 6.08 / Edius 6.54(b) / Neo 3.0 / Neo 3.5
Originally posted by vienna1944er View PostDear caminostereo..... please excuse.....both files are immediately deleted on the Server.....
neglects friend we are here to contribute and make EDIUS is great, thank you for your understanding also greetings from my beloved country PeruCSXD2 l For EDIUS Pro 6.5
Wait... what?
v1.01?
I forget what that looks like! :~)Rusty Rogers | Films
Originally posted by GrassValley_KH View PostActually, I believe this may be in reference to EDIUS Neo v1.01.
I'm not sure there'd be any reason you couldn't use these presets with Neo - certainly, they're all based off effects found in all software packages.
Because there is a small difference.
There are 3 packages form which you can install. They are all included in the dowload.
Support_A Edius 4.51 to 4.61
Support_B Edius 4.02 to 4.25
Support_ C Edius 3 and earlier
So if it is for NEO I think A would be the likely one that would work.Last edited by SRsupport; 08-26-2008, 09:48 PM.Steve
Originally posted by kruzer View PostDownloaded the filters but can't install it... does this work in Edius ver: 1.01?
Support A: for EDIUS 4.51 to 4.61
Support B: for EDIUS 4.01 to 4.26
Support C: only for versions of EDIUS 3.xx
I regret to say that "Cinema Suite 3.0" was not designed to EDIUS NEO 1.0, so you probably do not work properly in this version you have ..
GreetingsCSXD2 l For EDIUS Pro 6.5
I did some tests without problems... I think that they are ok for Edius 5Aristotelis Bafaloukos
BEng (Hons), MSc, MBCS
Ctrl+Alt+Delete
