UltraFX2
This topic is closed.
  • #91
    Originally posted by vidukalp_mary View Post
    Hi Prakashkrp
    I have ULTRAFX3 with USB KEY
    I have Some Problem....
    First of all you post in this topic that UltraFX2 & 3 Effects is convert in to Transitions Format But I do not show this effects in Transitions but it show in Keyers>Xplode Pro>Composer>UltraFx & UltraFM
    Second thing is that I export Project in AVI FORMAT
    But It can not played in Windows Media Player OR Any PLAYER & Can not Open in Procoder Also......
    If i am Export MPEG-2 Format it waste my time....
    I can convert 3 Hours AVI in just 30 Minutes & then I Open 3 Different PROCODER WIZARD & Export AVI TO DVD SAME TIME... in just 45 to 55 MINUTES.....
    Plz.. send me solution....
    Otherwise i think to return this DONGLE & SOFTWARE & Used Old DONGLE......
    ULTRAFX3 is good for Videographer's Editing but I have Lot's of Work so I can not Waste my time to Export MPEG-2 Format....
    Dear Sir,
    Thanks for using UltraFX3. In UltraFX3 u can use all your
    FX as a transition, for that you have to get training from your
    service provider.
    We have locked the AVI converts in UltraFX3 to protects our contents
    from unauthorise use. If you want it then you have to convert the avi by
    Pro-coder..then it will works.
    Can you tell me how did you converts 3 hours avi into MpegII in only
    30minuites ?
    Regards,
    Prakashkrp
    AVCS SYSTEMS INDIA www.avcsindia.com, Email : [email protected]
    • #92
      Follow the Screen shots to use 3dFX as Transition. But for Transition there
      limitation to use a 3d FX as you want like..placement; size; rotation etc.
      • #93
        How can i Open Ultra Fx3 AVI in Procoder
        Dear Sir,
        your question is how can i convert 3 AVI to MPEGII in 30 minutes ?
        I tell you in my first reply that i Convert 3 AVI to MPEGII in 55 Minutes......
        First you convert 3 (1 Hour) AVI in Edius this take about under 30 minutes...
        Then you close Edius & Now you open Procoder Express Wizard from Desktop & Convert First Avi to MPEGII, Minimize this Window... then you Open Procoder 3 Wizard Convert Second Avi to MPEGII, Minimize This Window & Then Last Open Procoder 3 (not Wizard-because already you use it) & Convert 3rd File to MPEGII.
        I have Core 2 Quad, 4 GB DDR2 RAM 800MHz, 1GB PCI Express CARD ATI 4650
        This system Take about 55 to 1 Hour Convert for All 3 Files AVI to MPEGII.
        Three Conversation At Same Time.....
        You try this and tell me about this.....
        But i have same problem that How can i convert Ultra Fx3 Made Avi in Procoder Because it is locked.... it can not open in procoder...
        Plz... do something about it.....
        I do not want waste my time for this......
        Otherwise i will return Ultra Fx3 Software & Donlge Back & Used Old Dongle.....
        I am very tired about this problem......
        I do not work very fast at this time.....
        You know that first you create projects... Then you convert MPEGII in Edius with procoder Express IT will takes about 45 minutes now you calculate the total Time of 3 Hours Export for MPEGII files..
        You tell me that You can create AVI with Procoder Express but it could not Open in Procoder Xpress without Edius......i means when i use procoder Directly on Desktop I can not Open AVI files convert from Edius with Procoder...
        What should Do now....?
        Tell me... waiting for your reply.....
        Kalpesh Patel
        • #94
          Hi,
          Thanks for your tricks to faster conversion. But I do not try this.
          Well you want to converts your avi from your desktop procoder.
          You mean stand alone ProCoder Express and ProCoder3, I think this should be possible.
          Let me know which key you are using? The 'UlraFX2' or 'UltraFX3'.
          Then I will try my best to shot-out your problem.
          Truly,
          Prakashkrp
          • #95
            Thanx for Your Gentle Reply Mr. Prakashkrp
            I am Using UltraFx3 Key (Safenet SHK) Dongle.....
            I pruchase this product 1 months & 5 Days Ago from (Hitech Video Vision) Ahmedabad.....
            I also Use Ultra Album which purchased 9 Days Ago From Same Dealer....
            I also create our own Projects Songs for HAST MELAP, MANGAL FERA, VIDAI & POTRAIT SONGS Also.....
            But.... I have only One Problem... at this time.... just i tell you in previous Reply.....
            Plz.. Do something..... for This problem.....
            I want use Procoder Express & Procoder 3 as Stand alone for Converting AVI to MPEG-II.
            I tell this problem.... to your Ahmedabad Dealer Mr. Prithvising & Technical Persons Mr. Ramesh Also.... But he answer that he could not solve this problem & I didn't Know more about this solution....
            He tell me contact you for this problem....
            Reply me & give me some solution as fast as possible... I am very tired for working with single Conversation & Sitting oppsite Computer whole days.... like this......
            Thanx for your gentle reply ..... thanx again.............
            Give me your YAHOO, MSN OR Other Messeger's Username for direct contact for chating & reply fast....
            • #96
              Dear Friend,
              I am little busy up to 25th May due to Vadodara Fair.
              After the day I will try my best to solve your problem.
              My MSN ID: [email protected]
              SKYPE ID: avc systems
              Handfone: 0-98109 84544
              ----Please----
              Prakashkrp
              • #97
                Hi
                Hi,
                I am waiting for your Reply & Solution for My Problem to Convert AVI to MPEG-II in Standalone Procoder 3 & Procoder Express......
                I am very tired from this problem......
                Plz... give me some solution for this.......
                Kalp
                • #98
                  Hi,
                  Kalp
                  I have atttached the ProCoder3.exe. Plz unzip it and
                  copy to your ProCoder3 folder. It solve your problem
                  *** LINK REMOVED ***
                  Hope it solve your problem.
                  Truly,
                  Prakash Kumar
                  • #99
                    Sorry, but linking to extracted ProCoder 3 .EXE files is not permitted.
                    (incidentally, the files were flagged by anti-virus)
                    • Hi, Prakashkrp
                      I am very tired.... now
                      I saw that you put a link in your reply,.....
                      But I saw that likn Removed by GRASS VALLY......
                      Plz... give me link on my mail address [email protected]
                      It's Urgent plz.....
                      Thank for your gentle reply....
                      • If you are not using the latest ProCoder 3 version, please download and install the update from the GrassValley site. Distribution of modified ProCoder files is against the license agreement. Not to mention, this forum is the not the appropriate place for this type of support for a third-party product. Please take it to email or PM.
                        • I think the company who is providing the plugin/templates must stay within reasonable borders and not use forum bandwidth for its general support activities.
                          IMHO
                          • What should i do now Prakashkrp ?
                            Hi,
                            I am waiting for your reply & New file link for PROCODER 3, PROCODER 3 WIZARD, PROCODER Express, PROCODER 2, PROCODER 2 WIZARD
                            Do something for me......
                            KALP PATEL [[email protected]]
                            INTEL CORE 2 QUAD 2.44, INTEL DG43NB, 4 GB DDR2, ATI 4650 1GB, 2x 500GB Seagate HDD [main], 2x 500GB, 2x 350GB [external]
                            • Originally posted by vidukalp_mary View Post
                              Hi,
                              I hope you noticed BH's post. You need to use a Private Message or Email for any continued questions on your problem. This forum is not for third party support issues.
                              • This thread has gone on long enough I think. If you are interested in getting further information about this software, please contact the Original Poster directly.
