Hi,
I have installed the Newblue Cartoon Plugin in edius 4.61 but have noticed that when I open up Edius the section where I select new progect is all black around the out side, I can still select or enter a progect name ect and edius starts normally, I would like to know why the progect setting page before edius starts is black around the edges of it.
Cheers
Hi Steve
after rebooting my PC, the startup screen has also turned black for me, there is clearly a bug with this plugin
I have renamed NewBlueCartoonR.tpi to NewBlueCartoonR.tpi-old (Plugins folder)
my startup screen is normal again, lets wait and see if the maker has a solution
Hi Anton,
Did renaming the tpi folder fix the black screen problem at start up?
Cheers
yes it did, but of course the filter no longer works while it is renamed, I just wanted to know if this is the cause and renaming is quicker than uninstalling
Can you please post a screen grab of that black start up screen. I am curious.
Steve EDIUS Trainer, Grass Cutter Gold
Looks cool though. Maybe the guys at new blue like black. he he
I like it. :)
I was also plagued with the problem of getting the plugin to work under EDIUS, but was able to get it to work by copying the tpi and dll files into the plugin directory under EDIUS.
This seems to fix the problem.
I don't know about my posting opening up any storm doors :), but I do feel that this is a very interesting plugin.
I may not post much here, but I am glad to help out in any forum, where I can.
Hi,
This black screen thing also happens with the WaveArt Audio suite which are VST plugins, BUT wavearts suite includes about 5 VST plugins, I have noticed when I remove one of the VST Wavearts plugins the black screen thing will go away, Very strange as NewBlue Cartoon effect is not a VST plugin though, the problem might be with Edius! Who knows, if anyone works out how to stop this black screen thing with NewBlue Cartoon effect please let me know.
Cheers
For the New Bluefx guys:
Did you guys buy out Hollywood FX? A lot of the effects are very similar to that program series.
When you ship these for GV Edius, will these work in RT or will they all have
to be rendered. Are your effects 100% GPU handled or what?
Just curious.
Did the installer not work for you?
Are you logged on as an Administrator? (sorry, had to ask) :~/
It's refreshing to hear from the folks from the other side of that "Big Blue Wet Thing" between here and where you are.
Even if not much happens, it's good to hear someone's listening.
I am logged in as administrator, and the installer worked fine (except that the installed couldn't register the product - I think it firewall related).
One possibility may be in the different file structure for installing the system on a Japanese system, instead of an English system (I'm checking this out with our developing dpt. guys).
And yes, we try to keep an ear open on things like this (even if there is a time-delay :) ).
