Edius x problem Vitascene
  • Edius x problem Vitascene
    Good morning
    I don't know how but vitascene version for edius X used to play without problems but now as I insert an effect the play stops almost immediately and turns red
    Before it went into play without blocking even if I inserted a filter
    I uninstalled and reinstalled vitascene and put the latest version but nothing
    I also formatted the pc to do a clean install but nothing is wrong
    Can you help me to solve the problem
    Thanks in advance
    my pc
    ASUS ROG MAXIMUS XII HERO motherboard ddr32gb
    i9 10900k CPU and rtx 2080 GPU​
    is it possible that you have a missing or corrupt nvidia driver? Vitascene requires the nvidia card to be working and have a monitor connected to it
    also, what is your buffer showing during playback without vitascene filter? what is your project setting? what are the source clips?
    make sure optical flow is not set as default https://www.videoproductions.com.au/...mo-default.png
      antonsvideo thank you for answering me
      yes nvidea drivers are all installed and up to date.
      I work with two monitors one attached to the motherboard and one attached to the nvidea card.
      optical flow is not active
      edius project in HD clips recorded by sony a7iii
      I don't understand why it was fine before​
        what is the buffer showing during playback without vitascene and with vitascene
        maybe one of the audio mixer channels is not in off position?
