Titler 7 and Edius X HELL!
  • Titler 7 and Edius X HELL!
    SO here is the user experience.
    Install seems to go well, Edius immediately requests an upgrade, timing I guess.
    I try out the new effects, thanks Vitascene, and the stabilizer, not as nice as Mercalli but faster maybe. Slo mo is nice
    Next day I open a show I need to make some outtakes of:
    This show has a series of titles made in TP5, when 7 was too buggy to take seriously on Edius 9..
    Well it seems 7 is even crazier on Edius X
    First I try to step through and check the titles, as I touch them up things are changing on other titles, even logos ended up in the wrong place. They were all fine when I started. Then I remove all the old titles from the job, annoying, and create two templates for the sponsor and the subject, Save them to the Library.
    This goes well. Now I create a new title, drop one of the templates on the new title and go to change the name and title,…. The world seizes up, click wait, type wait, eventually I check box out of TP7. Other windows apps on the machine seemed fine, no delays. Oh the timeline is locked, can’t do anything,” close all open dialog it says. Where? I alt tab, check the task bar, close all of Edius but the last window, no open dialog box, Have to kill Edius in Task manager. Trying to work through, this happens three times. I know killing in task manager is surely going to lead to a problems. And it does. Now even if EdiusX Opens a blank project, create new title, Title creates but no Titler Pro opens ever.
    Uninstall Reinstall same. Again, same. Clearly TP does not completely uninstall, as I can still see my templates in the library when reloaded.
    Now I get license errors on the edius X side so I have uninstalled it all.
    A lot of time is lost here, I have rolled back to edius 9 and titler 5 which although clunky, works.
    A lot of time wasted here, is there a fix or should we pursue a refund.?
    Machine is updated windows 10
    16G Ram
    RTX2060 with6 g Vram
    SSD’s for C drive and editing. System otherwise stable, stable in Edius 9 with TP5
    The user forum is not what it used to be.
    Jdroadie
    Philly, PA
    Edius 7.53 HDSpark, I7920, GTX470 Win7 64
    Would suggest you open a ticket with Newblue Support, they are usually pretty quick to respond.
    Take it you have TP5 & TP7 installed so care is needed to leave TP5 intact. Make this clear to Newblue.
    Sys1: Gigabyte Z370 HD3 i7 8086K(4.3Ghz), 16Gb ram, 256Gb SSD system + 2x2Tb Graphics: nVidia 1060, (W10 Pro) BM IP4K, E8v3 WG; Vegas Pro19; Davinci Resolve18_Studio, GH2(hacked), Pana HC-X2000E, GoPro5
    Sys2 :Clevo i7 6700K 2.5Ghz,16Gb ram 2565Gb SSD + 1Tb, (W10 Pro), Software: E8v3 WG; Vegas Pro19,Davinci Resolve18_Studio
    • jdroadie
      jdroadie commented
      Editing a comment
      got one going.
    I gave up using Titler ​ inside Edius and Davinci.
    Titler 7 on Edius X and Davinci 18 Studio.
    The only way for me to use it is using the Titler standalone and then export as video with Alpha.
    Being able to use it inside Edius would be by far most preferable way of course thought, if it were usable.​
    JoiCam´s
    And more
      I did find New Blue was much more stable with the CPU hyper threading turned off in the bios on my dual Xeon PC and there was no performance degradation in a multi layer test in Edius as a result. It stopped the white windows where Edius had lost the plot using New Blue Plugins. I use Vistitle which works well.
      You can give the bios tweak easily and give it a try.
      Regards
      • jdroadie
        jdroadie commented
        Editing a comment
        seems extreme but ok.
      have you contacted [email protected] yet
        That is best. As there can be some issues with an installation that NB can fix.
        @ the OP. Can you share on of your designs that gives issues? The reason I ask is that when we test, we need to see what effects you have applied. Some are depending on GPU and such.
        • jdroadie
          jdroadie commented
          Editing a comment
          Um so TP7 just doesnt open in Edius, except that it DID one session, lasted till I restarted Edius. Now it just creates a title but never opens, the Titles I created the day it DID work, now come up blank.
          Per the folks at New Blue I uninstalled / Reinstalled the whole kit, cleaned some registry even. Exact same thing no TP7 opens when we add a title.
        not sure this is related but noticed today E10.34.101 that the splash screen for TP 7 will show for a few seconds. never noticed that before.
        John Sirb
        Lake Breeze Video Lorain,OH
        SYS 1: Edius 9, Vistitle 2.5, Boris Red,Neat Video, Gigabyte Z170x G5, I7 6700K 4.0Mz Skylake, G.SKILL Ripjaws X Series 8GB x2, NVIDIA QUARTO 2000
        JVC HM-100,JVC HM-700, JVC HM-600, Canon 80D
          New Blue have been made aware of this
            Not bashing title pro any version but if you have AE the titles are great and easy to use. They work well on Edius timeline!
            Thanks,
            Ara
