it does not crash here with Win10 but due to an EDIUS X bug, the NR won't kick in in the first 10 to 16 seconds of the exported file
Excellent Plugin for Background Noise Reduction
Works fine here in Win 11 but with the caveat that Anton mentioned (though mine is not that long).1: 3970X Threadripper, Asus ROG Strix TR40 E Gaming, G. Skill Trident Z Neo 128G DDR4 3600, EVGA GeForce RTX 2080Ti, Samsung 970 EVO M.2 1T, Intel 660P M.2 2T (2), Seagate Ironwolf NAS 12T, Enermax TR4 360 AIO, Lian Li 011 DXL, AJA Kona 4, Asus ROG Thor 1200
works fine for me too with 14.11 but I got a 4 k monitor so the control is very small to seePC PRINCIPAL: intensificateur 4k pro - edius X- maximus heroX wifi - processeur Intel I7 8700K; mémoire 16 Go SKILL - xpredator2 - corsair 650W HX
Originally posted by sachem View Postworks fine for me too with 14.11 but I got a 4 k monitor so the control is very small to seeLast edited by antonsvideo; 03-16-2023, 04:13 AM.Anton Strauss
I've asked for handles to increase the size of the interface. I don't think that will happen.Last edited by Jerry; 03-16-2023, 03:52 AM.Jerry
Main System:: Azrock z690 Taichi, [email protected], 64gb ram, Lian Li Galahad 360mm in push pull, Lian Li 011 Dynamic XL ROG case, 13 Lian Infinity fans, Win11 Pro , Samsung 980 1tb boot NVME, 2TB Sabrent M.2 NVME, 2 TB WD 850x NVME, 1TB Samsung SSD, 12TB Raid 0, BM MINI MONITOR 4K, , Dual LG 27GK65S-B 144Hz monitors, GTX 1080ti SC Black Edius X.
Second System: EditHD Ultimax-i7, X58, [email protected], Corsair H80, Win764, 24gb ram, Storm 3g, Samsung 840 Pro 256, 4tb and 6tb RAID 0 on backplane, GTX 980ti Classified, Edius 9.55, Apple 30", Samsung 24", dual BD.
I have Windows 11 extend on 2 monitors. EDIUS crashes when opening the plugin on the 2nd screen. I simply brought the Clarity window back to the 1st monitor and it worked. I have no explanation.You do not have permission to view this gallery.
This gallery has 1 photos.
Originally posted by Malastreg View PostHello,
I have Windows 11 extend on 2 monitors. EDIUS crashes when opening the plugin on the 2nd screen. I simply brought the Clarity window back to the 1st monitor and it worked. I have no explanation.1: 3970X Threadripper, Asus ROG Strix TR40 E Gaming, G. Skill Trident Z Neo 128G DDR4 3600, EVGA GeForce RTX 2080Ti, Samsung 970 EVO M.2 1T, Intel 660P M.2 2T (2), Seagate Ironwolf NAS 12T, Enermax TR4 360 AIO, Lian Li 011 DXL, AJA Kona 4, Asus ROG Thor 1200
I'm using a dual set up. Nvidia for main and Intel 770 iGpu on the 2nd monitor. No issues here on Win 11.Jerry
Well guys...sh..t! I've tried everything. For 2 weeks! Same issue - strangest thing. I installed the latest version of EDIUS earlier this weekl, Opened up the EDIUS X file in the upgraded version - and there it was - Clarity VX. I was thrilled. Edited quite a while using the Clarity VX. Next day booted to EDIUS, loaded the same file I had partially edited the previous day - and VOILA - NO Clarity Vx. "Dummy Effect has been substituted for missing Effect"! Strange. I've followed everything everybody has suggested in this Post. I'm close to quitting WAVES.Alan J. Levi
Director
Hi Alan
I have not had it vanish on me, can you generate a system report in EDIUS help menu and attach here or send to me, I have a support tool to check it
meanwhile, EDIUS needs fixing before we can use Clarity VX correctlyAnton Strauss
I've never had it disappear either. I would suggest using a separate audio program that accepts Waves as a plugin. I use Audition and round trip the audio. It's faster
than trying to make it work properly in Edius X. Premiere and Resolve accept Waves plugins.
A Few Other Windows Waves Hosts:- Pro Tools2022 AAX Native, Audiosuite
- Ableton Live11.2VST3
- Nuendo 12 VST3
- Cubase 12 VST3
- Audition 23 VST3
- Premiere Pro 23 VST3
- Studio One Professional 6 VST3
- FL Studio 21 VST3
- REAPER 6 VST3
- Reason 12.5 VST, VST3
- Maschine 2 VST, VST3
- Komplete Kontrol 2 VST, VST3
- Bitwig Studio 4 VST3
- Cakewalk by Band Lab 2022 VST3
- Samplitude Pro X7 VST3
- Sequoia16 VST3
- Pyramix 14 VST3
Hi Anton - attached is the requested System file. HOWEVER - HOWEVER - Just found out the clue to having the WAVE Clarity Vx in the Effects list. You HAVE TO be actively connected to the internet ! ! ! I usually do not connect as a habit - too many network interruptions and chances for hacking on my dedicated Editing computer. But it seems that the WAVES website must be available in order for this program to be authorized each time you load EDIUS. Hooray - and thanks for the help, as usual.!!!Attached FilesLast edited by AJL14; 05-15-2023, 02:49 AM.Alan J. Levi
Director
Hi Alan
several questions
1. I can see X WG and X Pro license in your LM, which one are you using?
2. can I see a screenshot of the contents of C:\Program Files\VSTPlugIns
3. can you confirm that C:\Program Files\VSTPlugIns is excluded from your Norton internet security
4. can you confirm that all 3 Grass Valley folders are excluded from your Norton internet security (program files/grass valley, appdata/roaming/grass valley, program data/grass valley)
5. can I see a screenshot of your VST plugin bridge as seen in attached example
Attached FilesLast edited by antonsvideo; 05-15-2023, 03:31 AM.Anton Strauss
Thanks Anton. I will get to all your requests ASAP, but today and tomorrow are big shopping sprees with my wife for things we need for our France trip coming up. So, be patient and I'll get to my answers as soon as I can get upstairs to my editor. I appreciate your going over my report so quickly. Ciao, AAlan J. Levi
Director
