sometimes new VST don't show in effects panel until you right click the effects panel and restore to default
Excellent Plugin for Background Noise Reduction
Originally posted by sachem View Post
Now, can we have a screen shot of your VST Plug-in Bridge.
I've included a screen shot of the VST Plug-in Bridge.
You need to link the VST Plugin Folder within the VST Plugin Bridge.Attached FilesJerry
Main System:: Azrock z690 Taichi, [email protected], 64gb ram, Lian Li Galahad 360mm in push pull, Lian Li 011 Dynamic XL ROG case, 13 Lian Infinity fans, Win11 Pro , Samsung 980 1tb boot NVME, 2TB Sabrent M.2 NVME, 2 TB WD 850x NVME, 1TB Samsung SSD, 12TB Raid 0, BM MINI MONITOR 4K, , Dual LG 27GK65S-B 144Hz monitors, GTX 1080ti SC Black.
20220423_150853[1].jpg it's what i did - only cla vocal appearsPC PRINCIPAL: intensificateur 4k pro - edius X- maximus heroX wifi - processeur Intel I7 8700K; mémoire 16 Go SKILL - xpredator2 - corsair 650W HX
The Waveshell file is just a wrapper/translator to convert the native waves format into a a vst format.
with that in mind a question:
are you sure you have installed the plugin? Check in the waves folder to ensure it is there. If it is there, the waveshell translator should see it.
and, another thing to try would be to do a reset on your edius effects pallet/browser. Sometimes resetting that will get it to display everything correctly.Edius WG 9.55.9157, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
Yes I did a reset of effects pallet/browser and my plug in is installed..
When you installed the plugin, if you had a choice of plugin version, did you install the 64bit vst2 version? Since Version 8 if i recall, Edius will not load 32 bit plugins and will not load original vst or vst3 versions.
If you have the correct version installed, do you have any other software that can see the plugin, such as reaper, audition, audacity, etc.? If other software can see it, then it may not be an Edius specific problem.Edius WG 9.55.9157, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
What about vs Acon Denoiser?Pawel Chyrowski
Edius 9 Workgroup
No comparison. Only works in Edius X forward.Jerry
I found out that Acon Digital DeNoise EDIUS Edition works very well. Recently, I have removed the wind noise and the sounds of the forest with this plugin. It's not competition for sure, but it is a good free alternative.
Cheers JerryLast edited by Seemedia; 05-17-2022, 01:38 PM.Pawel Chyrowski
Edius 9 Workgroup
So I bought it. I copied the dll file to the Plugin / VST folder and it works finePawel Chyrowski
Edius 9 Workgroup
Originally posted by Seemedia View PostSo I bought it. I copied the dll file to the Plugin / VST folder and it works fineAnton Strauss
You bought what?
Pawel Chyrowski
Edius 9 Workgroup
do you mean Clarity VX?Anton Strauss
I'm trying to use the Waves Clarity Vx audio plugin (v14.0.0) with Edius X (10.34 - Windows 11).
I indicated in the system settings/Effects/VST Plugin the path to the Clarity DLL (c:\program files\VSTPlugins)
I get well in the VST2 folder Audio Clarity Vx Stereo Filters
But...when I open the Edius configuration box, it crashes.
Has anyone managed to use it under Edius X?
Have a nice week end
malaYou do not have permission to view this gallery.
This gallery has 1 photos.
I hadn't tested Clarity VX in 10.34 with Windows 11 Pro yet. I just did and you can see the screen shot.
Attached FilesJerry
