Excellent Plugin for Background Noise Reduction
  • Excellent Plugin for Background Noise Reduction
    Yesterday, I picked up the Waves Clarity Vx plugin. This EASY to use plugin does some incredible things.
    You can find it here: https://www.waves.com/plugins/clarit...oise-reduction
    On this same page you can watch a video about the product as well as get a demo. The plugin is on sale for $29.99 US.
    My use for the plugin is for voiceovers in which I need it to knock out AC, Ceiling fan, and Computer fan noise.
    The clip I used has a lot of wind. It really surprised me.
    https://we.tl/t-Po9tTG0Buu
    Let me add that the plugin uses AI to make things work.
    I have to echo what Jerry said about this. I tried it on a dirty recording that I had for an audio test that I made with lots of ambient sounds and it sorted it perfectly. Needless to say, I bought it. Jerry's video is a great example of combating wind wind which is usually an impossible nightmare and fix for videographers. This plugin is simply amazing. For any of you that shoot on site and have to use that audio (no ADR), this is a must $30 buy.
    I think the EDIUS X support of WAVES audio effects is one of the unsung features that people don't talk about enough.
      The Clarity VX and the NS1 noise reduction plugins are excellent additions to any editor's toolkit.
        has anyone tried Acon Digital Extract:Dialogue 1.x? I have used it a few times and its fantastic.
          Does Clarity Vx work with E9.x?
            it should work but remember to check lip sync because only EDIUS X has VST delay compensation
              will it work with edius 7?
                I have Clarity Vx working in Audacity, but nor in E9.52. The WaveShell1... .dll file is in the Edius VSTplugins folder. Any suggestions?
                  I gave up on trying to get waves plugins to work in Edius. They are supported in Edius X but never were in older versions due to the waveshell.dll as far as I can determine. The waveshell.dll is a plugin wrapper that translates the waves native format into a "virtual VST plugin". If the plugins were actually written as native VST plugins, they probably would work.
                  Edius X has officially added support for the waveshell.dll translation.
                  Edius WG 9.55.7761, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
                    Bern has explained the waveshell wrapper perfectly. WAVES plugin support started in EDIUS X. That's why I said I thought it was an under appreciated addition.
                      Thanks for the info. (Not what I wanted to hear but such is life.)
                        Waves plugins are well engineered, easy to use, and they just work. You can build a great plugin library with essential tools, that are reasonably priced.
                          Agreed. They are good and we use them extensively in our DAW systems. The issue is that a lot of NLE systems were never designed for compatibility with the waveshell.dll wrapper, not just Edius. Now that Edius X has support for it and the automatic latency compensation though, it is a whole new world for audio in Edius
                            Has anyone compared RX9 Advanced to those Waves plugins?
                            I have RX9 Advanced but the price difference is huge compared to Waves, I have highly respect for Waves and their plugins that I have been using a lot in audio productions but never tested their cleanup tools.
                            JoiCam´s
                            And more
                              They both work really well.
