Edius X- installing Vitascene 4 plugin
  • Edius X- installing Vitascene 4 plugin
    Could not find any documentation on how to install Vitascene 4 plugin to Edius. Any help is greatly appreciated! running win 11
    Main System- HD Storm + Edius 7 Pro
    Win 7 (64),Asus P6T Deluxe v2 - Intel I7 - 12 G ram Gforce GTX 970 - 6 T internal-- 12 T Drobo Sata connection
    Secondary System- Edius 6- Win XP, Intel DH55HC i5 4T storage, 4G ram, Gforce GTX 260, , ADVC110
    Just run the installer, which is the download.
    My System: Edius Workgroup 9.51 & 10.0, Intel I9-9900K 3.60GHz Liquid Cooling, MSI Z390-A PRO MB, 32-GB Mem, GeForce GTX 1660 6GB GPU, BM Intensity Pro 4K Card, Win 10 Pro
      When I installed Edius x, (full version), Vitascene 4.0 was installed as a seperate application, but does not appear in the filters of Edius--
        I don't have X or vitascene, but generally plugins are installed by the application/plugin installer (vitascene in this case). If the installer recognizes Edius X and has a compatible plugin file, it will normally install it or at least ask you if you want to.
        If Vitiacene is not Edius X aware it will not install the plugin. If it is Edius 9 aware, it may have given the option to install an edius 9 plugin, which you may be able to copy from an edius 9 plugin folder into your edius x plugin folder. You will have to look on your system and see if the files are there or re-run the installer and see if you may have skipped over an Edius X option.
        Edius WG 9.55.7761, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
          Got it! again, many thanks!
