Originally posted by gameroja
View Post
Audio output with Edius X
so you use powered speakers, why not connect them to the TV, surely the TV has a headphone output, so you use a headphone 1/8" stereo jack to stereo RCA splitter cable, I have several laying around hereEdius WG 9.55.7761, various 3rd party plugins, VisTitle 2.9.5.6, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
Storm card was great, HDSpark, the same. I am a bit tired that with the years we are loosing simplicity. HDSpark is not compatible with Edius X. Edius X needs Windows 10. So, we have to make very often more and more changes in hardware and software. Hope Grass Valley makes an HDSpark 4K
Originally posted by gameroja View PostStorm card was great, HDSpark, the same. I am a bit tired that with the years we are loosing simplicity. HDSpark is not compatible with Edius X. Edius X needs Windows 10. So, we have to make very often more and more changes in hardware and software. Hope Grass Valley makes an HDSpark 4K
I still think your issue with your IP4k sounded like the firmware update never got applied. I did one install of an IP4k that I could not get to update, so I pulled it and stuck in in a different computer with different hardware, applied the drivers and update and then placed it back in the intended system. I have no idea what was causing the firmware to not install, but once I did that, future driver installs were able to update the firmware. You may have been too quick to throw in the towel and return the card.Edius WG 9.55.7761, various 3rd party plugins, VisTitle 2.9.5.6, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
Thanks BernH and Anton for your advises. Yes, maybe I had no patience, but also because I don't need so urgently to make the whole change to 4K-10bit and also update to EdiusX (even if I paid for the Edius update). I will wait (patiently) for new hardware.
FWIW: HDMI audio splitter are available for under US$25 from Amazon and other sources. They pass the HDMI signal (up to 4K) through while providing separate analog RCA and SPDIF audio outputs. Useful if your monitor/TV does not provide separate audio output jacks.
