Audio output with Edius X
    What do you mean by its terribly loud? Are there any audio output level settings in the BM Desktop Video Setup app?
      Originally posted by gameroja View Post
      After a couple of hours with the Intensity Pro 4K, I can say that I'm planning to return it: is terribly loud and it is not possible to deactivate when I am out of Edius. I am searching for a simple card like the HDSpark, but with 4K support. Do you know another alternative for the same prize as the Intensity? It's just for having video and audio output with left and right RCA. It's a pity that Grass Valley doesn't update HDSpark
      If you are referring to the fan noise (sounds like it since you say it is loud outside of Edius, but you didn’t exactly say what is loud), this was cured by a firmware update that came out after the card was released. When you installed the desktop video drivers, you should have been prompted to update the firmware and then reboot. If you did not get that prompt, it may be that your virus scanner is blocking the firmware update from running.
        Yes, the fan is very, very loud, even with the new update. And it is not possible to deactivate to use only for editing. Is all the time running. I think I will return it. I bought also the Edius X update, but I prefer Edius 9, because I have problems all the time with exporting: I don't see the progress of exporting and if it happens or not. So, I will stick with Edius 9 and HDSpark for the moment. Thanks a lot
          if you select add to bin, you will see the export progress bar in the bin thumbnail
          https://www.videoproductions.com.au/...n-progress.png
          I have no issues with 10.30 but I don't use 11th or 12th Gen CPU
          I am using a BM Mini Monitor 4k and can't hear its fan at all. I guess the Intensity Pro fan is louder?
            Thanks for the advise about exporting. Edius is sometimes complicating things and people don't want to loose time researching. Yes, the fan of the Intensity is very loud and I don't find the way to deactivate the card when I don't use Edius as HDSpark does. Only through devices administration in Windows
            • #21
              which BM driver version are you using?
              • gameroja
                gameroja commented
                Editing a comment
                Desktop Video Installer v12.2.2
            • #22
              Loud doesn't sound right. My IP4K fan is quieter than the case, graphics card, and CPU fans. Did BMD change to a different fan during the production run as well and if so, perhaps you got old stock.
              • #23
                No loud doesn't sound right. When i was using my IP4k (which I will have to go back to for Edius X when I make the upgrade), the initial installed drivers did not update the firmware, so the little fan on it was on full speed all the time. i decided to put in my older IP original version while I did a little research and decided what to do. Everyone was complaining of the same issue, so while I waited to see if BM would fix it, I also looked at possibly replacing the fan with something else. BM did release new drivers that installed a firmware flash and like Don the fan noise went from unbearable to about on par with any other fan.
                So once again, if you didn't see the firmware update window when installing the drivers, something is blocking it. The update does require a reboot for it to install properly, and you will see a little window come up after the reboot too if I recall. If you haven't seen that, your firmware has not been updated, and something has blocked the process.
                • #24
                  is terribly loud
                  There must be something wrong with this unit as my Intensity Pro 4K is near silent, the only thing I hear from my pc are the cooling fans that are build into the pc case.
                  • #25
                    Maybe is my card. I returned it and reinstalled the HDSpark, which is perfect for monitoring audio and video with its two RCA connectors directly to my powered speakers. The problem: I can't monitor 4K through an external TV and it doesn't work with Edius X. I stick for the moment with Edius 9, which has everything I need and use my own PC Benq monitor for color correction. The external monitor it's just 2K. I wanted to make the change to watch everything in 4K and 10 bit on an external TV, but I don't see good solutions at the moment. A pity that I paid for Edius X update.
                    • #26
                      the Mini Monitor 4k makes no fan noise and works perfect for me, no RCA needed, audio is delivered via HDMI
                      • #27
                        Thanks Anton, Mini Monitor 4K would be perfect if they had RCA connectors. My two Yamaha HS5, which are great for monitoring audio, don't have HDMI connections. The have XLR ones. I don't need amplifier: directly from RCA to XLR.
                        • #28
                          but doing it your way, the audio will be out of lipsync
                          does your TV have an audio out connector (even headphone) that you could feed to your Amp?
                          also, many TV have optical audio output and many Yamaha Amps have an optical input
                          • #29
                            ...many TV have optical audio output and many Yamaha Amps have an optical input
                            That is the way I have seen most of the time on setups like this.
                            • #30
                              I don't use an amp. With the HDSpark I can connect with left-right RCA both speakers directly. And with perfect lipsync. Would be great if Grass Valley makes an HDSpark 4K 10bit
