Latest Edius X No Sapphire 2022 in OFX Bridge
  • Latest Edius X No Sapphire 2022 in OFX Bridge
    Hi
    Any ideas as to why Boris FX Sapphire 2022 doesn't show up in OFX bridge in Edius X or Edius 9? (It works just fine in DaVinci Resolve Studio on same PC)
    Mike, I just downloaded the trial of Sapphire 2022 and it shows up in Edius X 10.30 using OFX Bridge version 3.0.210609
      Originally posted by createmedia View Post
      Hi
      Sapphire 2022 shows here in EDIUS X.
        I also have OFX Bridge 3.0.210609 and Sapphire doesn't show. I uninstalled, deleted all the folders to do with Sapphire downloaded the OFX trial again but no Sapphire appears in the NB OFX Bridge. The only thing I haven't yet tried is a re-start. Applies to Edius 9 and X.
          No a re-boot didn't help
            Strange.....maybe you should contact New Blue
              Also you have not registered the Bridge?
                I have contacted NewBlue beginning of last week but apart from the automated reply a stony silence
                  These are the Workgroup versions of 9 and X I am trying it in.
                    maybe resetting the effects panel make them appear?
                      Registry problem with the NB OFX entry and Sapphire.
                      Edited registry and resolved.
                        Hi
                        Hello, where can I download ofx bridge version 3.0.210609?
                        CPU:AMD R9 5950X GPU:GTX1050 MEM: Micron 4G DDR4 2400x4
                        motherboard:ASrock X570 matx
                        SSD:intel p3600 sata HDD: HGST 8Tx5 raid0
                        Power:Great Wall EPS2000BL 2000W
                        OS WIN10 20H2
                          basically nowhere as it is not yet available to the public
                          you can ask NewBlue support for it and if you can't get it, I may upload it via wetransfer, but it is 800MB
