ofx bridge with cosmo from magic Bullitt, still crashing
  • ofx bridge with cosmo from magic Bullitt, still crashing
    can't use cosmo from magic Bullitt , now cal maxon. when i apply this cosmo or the look's i either crash or get this message. can anyone help with this issue. only edius 8 was the last time it was working.
    AMD Ryzen 9 3900X 3.8GHz [4.6GHz Turbo] 12 Cores/ 24 Threads 70MB Cache 105W Processor
    SSD: 512GB Intel(R) 660P SERIES PCIe NVMe M.2 SSD
    850 power suply
    32GB (8GBx2) DDR4/3000MHz
    ASUS TUF X470-Plus Gaming AM4 ATX
    EVGA GEFORCE RTX 2080 SUPER GPU
    Windows 10 Pro
    HDD: 8TB (8TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM
    What OS, Edius version and OFX version are you using?
    The only supported Edius OFX effect supported in Edius X and the OFX Bridge 2 is Sapphire.
      edius 10.7 and ofx is newest update
      850 power suply
      Windows 10 Pro
        where did you get EDIUS 10.7? I am only on 10.2
          sorry Anton i forgot to go back to check this forum, i may have typo error it's probably 10.02
          850 power suply
          Windows 10 Pro
            Magic Bullet is no longer supported in Edius. As I mentioned in post #2, the only officially supported OFX plugin is Boris Sapphire.
              Correct. ......As far as I know the latest versions don't even show up trough the bridge.
                I use Magic Bullet look in edius x as a preset (made in edius 9) that works but I cannot open it after .
                PC PRINCIPAL: intensificateur 4k pro - edius X- maximus heroX wifi - processeur Intel I7 8700K; mémoire 16 Go SKILL - xpredator2 - corsair 650W HX
