Vitascene for intros to videos
  • Vitascene for intros to videos
    I've never used After Effects but appreciate its regarded as the King of video animation but how powerful is the Vitascene with Edius X?
    Anyone using it?
    will Vitascene v4 pro work in edius 7?
      Anyone using it?
      Vitascene has cool filters and transitions, especially the new Seamless Transitions
      but it is not an animation software at all
        it works with 7, 8, 9, 10
        https://www.prodad.com/Video-Effects...4125,l-us.html
          Comment installer Vitascene V4 dans Edius 9 ?
          EDIUS 9, Asus Prime X570-P, Rysen 5950x, 32 Go DDR4,
          Asus Hyper M (3 x 1 TB NvMe), MSI Armor GTX 1060 6 Go
          WIN 10 pro
            yes, it works fine with EDIUS 9
              How to install Vitascene V4 in Edius 9?
              What is the procedure ?
              Thanks for your help
              WIN 10 pro
                you double click the installer.exe
                or do you mean you want to install Vitascene4 for EDIUS X to EDIUS 9? if so, just install it for X and then copy the tpi from the X plugins to 9 plugins folder
                  The installation of V4 is successful.
                  I find the V4 effects in Edius 9.
                  However the thumbnails are fixed and all marked V4.
                  Is it possible to get animated thumbnails?
                  If possible, how do you get them?
                  Thanks for your help.
                  WIN 10 pro
                    I can't repeat that, I see thumbnails and when I click, they animate, see attached
                    did you buy V4 and activate it? or are you using the free version that comes with X?
                    did you install it on the PC with EDIUS9? if you just copy the tpi from an EDIUS X PC, you will not have thumbnails because the program also needs to be installed. You can have EDIUS X and 9 on the same PC, then you can copy the tpi and it will work in 9 and X
                      I work with Edius 9 and it is a V4 version offered (?).
                      Aside from the lack of preview effects in the thumbnails, everything works just fine.
                      WIN 10 pro
                        I come back with the same subject ...
                        This time with an official version of Vitascene 4 that I see the problem.
                        The thumbnails are not animated.
                        Is the problem posed by a bad configuration of Win10?
                        Thank you in advance for your help.
                        what is the tpi ?
                        WIN 10 pro
                          the tpi is the prodad.tpi plugin you should find in the EDIUS Plugins folder
                          I have no issues with the thumbnail animations in Win10, it also worked the same in Win7
                          send an email to [email protected] and they will soon give you some things to check
