New Blue not working well in UHD 50p projects
  • New Blue not working well in UHD 50p projects
    Hello
    Sadly New Blue is not very usable in UHD 50p.
    Test PC Dual 18 Core (72 threads) Xeon 2.3GHz, 3.6GHz turbo (all cores in turbo 2.8GHz) 64GB RAM NVIDIA GTX 1080TI watercooled GPU
    Titler 7 works ok in HD with real time playback with resolution at 1/2 but it cannot play in UHD and the resolution reduction does nothing to help.
    (This is the Titler clip on its own with no other video to play at the same time).
    NB support recognise that this is a problem for them to solve and the CPU activity is below 30% when trying to play with one random core occasionally peaking 100%.
    Multithreading not working? (On my older systems with Edius 8.53 NB other plugins were better behaved on those as they were dual 4 core 3.6GHz Xeons without multithreading).
    BUG (accepted by NB) if the V button top left of the timeline is off (the last activity might have been to drag audio only over to the timeline) the other titlers will not launch. NB Titler 7 will launch but locks the timeline and the titler GUI is nowhere to be seen. Only option is to crash out of the Edius app.
    I then turn to the OFX bridge.
    With my OFX list below it takes the bridge 1.5 minutes to assess which OFX plugins it likes and which ones it will reject, and it does this once per Edius session. The next time the bridge is accessed in the same edit session it opens instantly but does not show all the installed OFX plugins.
    I must not click on anything at all during this check or Edius will crash.
    Boris BCC OFX Bundle: working (But Chroma Keyer can crash Edius)
    Boris OFX 3D objects bundle: working
    Boris RED OFX bundle: rejected
    Ignite Core OFX bundle: rejected
    Ignite Pro OFX bundle: rejected
    Magic Bullet suite: working
    ProDAD Vitascene 4: working
    Digital Anarchy: working
    Sapphire OFX bundle: rejected
    All my above OFX plugins work just fine in DaVinci Resolve as a comparative test which then says to me it is a bridge issue not an OFX installation issue.
    NB OFX bridge 2 at version 3.0.210609
    If an OFX effect has been added to a clip in a project Edius takes a long time to load the project and it will prompt the crash reporter "taking too long" (probably because it kicks off the OFX checker in the background)
    If the plugins are all OFX compatible they should all work in the bridge, not just some of them, and as Resolve is happy they are all compatible, the bridge needs to be fixed.
    Rating 3/10 not a good experience for me in 4k/UHD as it currently stands.
    Edius.net support recommend any examples of problems with NB should be sent to NB support as it is NB who need to fix the issues and the more people that do that NB will be pressured to fix it. I have done that myself.
    Regards
    Last edited by createmedia; 08-17-2021, 11:37 AM. Reason: Additional sentence to add
    Mike:
    1. There is a newer version of the Bridge-210216....I seriously doubt that it will help with playback.
    2. Continuum is not supported in Edius by Boris. Steve has labeled it as a 'use at your own risk' product.
    3. Why are you using the Ignite Pro OFX version? The last OFX version I used was in the 1.x series. There is a native interface for Edius.
    4. Sapphire is the only compatible OFX plugin in Edius X.
    5. Be sure to wait until the green circle around the play button is complete (this means fully rendered) prior to clicking the green check mark to return to Edius.
    6. How do Vistitle titles perform in the same situation?
    I can get UHD 50p playback in Edius if I Shift+G render the NB title and set the resolution dropdown to Full 8bit (with HQX-1/2 with AVC).
    Also, if you are using H.264/265 files beneath the title, transcode these to HQX to improve performance.
    There is an issue with NB titles not retaining renders.
    I'm running a 4790k at 4.6GHz with an overclocked 1080ti.
      Hi Jerry
      Vistitle works pretty well for me in UHD but I am mainly using it for subtitles. 2.95 is real time even over a chroma key on a XAVC 50p clip.
      BCC works pretty well.
      Ignite installed the OFX version, but it doesn't show.
      Sapphire doesn't show but Resolve is happy with it so why doesn't Edius see it?
      I updated Titler and Bridge last week directly in the NB App manager and that was the bridge version I got.
      What I am having to do is have a shortcut on the desktop for OFX plugins and another folder for OFX removed plugins and remove the no show ones first as I can't cope with the 1.5 minutes check and reject cycle that I am getting now when first opening the bridge in Edius.
        Just heard back from NB support.
        Real time playback optimisation for NB plugins in Edius for 4K/UHD is not expected until 2022
