OFX Bridge 2 bug in the 23.98 project?
  • OFX Bridge 2 bug in the 23.98 project?
    Hi,
    I noticed strange OFX Bridge 2 behavior, which in some cases stops my work completely.
    I work on projects with 2 types of frame rate: 29.97 and 23.98. If I use FilmConvert plugin in 29.97 project, everything works well if I do render In/Out (render loaded area) or print to file. However, if I use FilmConvert in 23.98 project, I run into an insurmountable bug. To begin with, render In/Out (render loaded area) does nothing (I'm still playing loaded area slowly). Most importantly, when I try to print to file, I get a gray frame instead of my video clip. Magic Bullet Looks works great in both types of projects, however FilmConvert or Magic Bullet Film does not work completely on project 23.98 (Magic Bullet Film just "turns off").
    My disposal:
    Edius X 10.20.7490
    OFX Bridge 2 3.0.210216
    FilmConvert 2.20
    Maybe related to this?
    https://forum.grassvalley.com/forum/...301#post564301
      Originally posted by ngrin View Post
      Hi,
      My disposal:
      Edius X 10.20.7490
      FilmConvert 2.20
      I just tried with Fim convert Nitrate and it seems to work correct in EDIUS X.
      Both the rendering and export.
        I just downloaded and installed the latest available (trial) filmconvert version 3.04. Now the frame just turns black after applying the effect.
          Could this be hardware problem? Let me remind you that I have problems with any film emulation effect, be it Film from Red Giant or FilmConvert.
            Currently the only ofx plug which is compatible with EDIUS x trough the NB OFX bridge 2 is Sapphire.
            Looks is incompatible.
              I forgot to add that your black frame issue is a known issue. If you set the preview to 1/2 res you will get a blackv-frame in the preview. If you set the preview to full all is well. This one of the reasons we have not listed this as compatible unfortunately.
                So do I understand correctly that the FilmConvert plugin is not officially compatible, but it works for you correctly?
                  It works correctly when Preview is set to full (with some incidental issues) but this is not an official endorsement. It is more a use at your own risk issue.
                  I have only used it with the GH5 camera pack.
